ok, that is EZ...
check
this thread out, it has a pretty good discription of the process
just take a thin wire & make a jumper & guess at a pair of terminals, if it works then you found your points, if it don't work try another, repeat till you hit the pair that will start it up, then follow that thread for making your connection
good luck with it
I think I'm going to try to sticky that thread in the laptop forum for now, till I get a more polished tutorial togeather at least
