The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 02-23-2008, 06:11 AM   #16
Thefdog's CarPC Specs
Vehicle: 2002 Civic LX
My Photos: (0)
Here's a simple diagram for you
Take a look at the following link, it should help alot:
http://www.rowand.net/Shop/Tech/AllAboutRelays.htm
All automotive relays are wired similarly, and everyone that I have seen use this numbering code for the wiring. Think of a relay as an electrically controlled switch (which is exactly what it is), that allows a small current flow to control the flow of a high current through it.
As the image shows, the main power from your battery (fused close as possible to the battery) will connect to #30 on the relay. Wire the line for the trigger (#86) to a source that is on when the car is on, such as your radio, lighter, axillary fuse, amp turn on line, power antenna line, etc. You can safely splice into this line, as it will not be carrying much current. Wire the ground to #85 (it does not have to ground to the same location as your audio equipment and carputer, but it can). The wire carrying power to your fusebox will connect to #87, the "normally open" connection.
When the relay is energized (when the ignition is turned on) with the current from whichever circuit you choose, it will close the relay, allowing a higher voltage current to flow to the fusebox.
This type of power controller works very well with a laptop, as you can turn the car off and the laptop can continue its shutdown procedure on its own battery power. No waiting for the computer to finish shutting down or hibernating before turning the car off and getting out.
Let me know if you need more help
Thefdog is offline   Reply With Quote
Sponsored Links
Old 02-23-2008, 06:12 AM   #17
My Photos: (0)
Take a look at the following link, it should help and is the source of the diagram below:
Old 02-23-2008, 06:17 AM   #18
My Photos: (0)
Make sure to connect to normally open circuit
I forgot to stress that you need to ensure that you wire it to the normally open circuit. If you wire it to the normally closed circuit, when the car is off, it will be powering your fusebox = dead car battery.
Cheers and good luck
Old 02-25-2008, 06:07 PM   #19
My Photos: (0)
thanks Thefdog, that was what I was looking for..newbies guide to wiring a relay for power purposes.
colbyau is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
2000 BMW 323i E46 Laptop install Magician Worklogs 5 08-03-2006 10:15 AM
Would this work? Laptop to remain on 24/7 thwang99 Laptops, Tablets, UPMCs, etc. 9 02-16-2006 05:59 PM
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 03:37 PM
2005 Altima (black) laptop install + PSP integration aeiz Worklogs 6 06-14-2005 04:43 AM
Laptop Install Help!!! Inspiron8500 General Hardware Discussion 8 07-02-2004 10:21 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
