The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 02-07-2008, 03:22 PM   #1
My Photos: (0)
Momentary switch, how many amps?
I'm setting up a startup controller to my docking station. I will run 22 gauge wire to turn on the laptop via momentary switch. Does anyone know which momentary switch I should use? There's one that is 0.5 amps and the other which is 1.5 amps.
hardcoreracing is offline   Reply With Quote
Sponsored Links
Old 02-07-2008, 03:26 PM   #2
Raw Wave
Rob Withey's CarPC Specs
Rob Withey's Avatar
Vehicle: '97 Vauxhall Corsa 1.5 TD
My Photos: (0)
either will be fine.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 02-07-2008, 03:30 PM   #3
My Photos: (0)
momentary switch
Thanks for the quick reply. I think I'll go with the 1.5 amp switch then since it's bigger and looks more sturdy.
Old 02-10-2008, 12:56 AM   #4
My Photos: (5)
it doesnt really matter. all you are doing is jumping two pins
hari-bhari is offline   Reply With Quote
Old 02-10-2008, 06:43 PM   #5
pancit175's CarPC Specs
Vehicle: 96 Talon
My Photos: (0)
At the very most it would use 200mA if that.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 02-10-2008, 07:04 PM   #6
lbridges's CarPC Specs
Vehicle: 2002 Toyota/MR-2
My Photos: (8)
As a point of reference, I'm using a telephone extension wire to turn on mine. It's wired into the unused modem port. What gauge wire is that...around 28?
lbridges is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Simple and Clean Remote Laptop Power Switch WarDriver Laptops, Tablets, UPMCs, etc. 25 07-23-2008 09:57 PM
this is how to bypass laptop button and standby switch andyman Laptops, Tablets, UPMCs, etc. 1 12-18-2007 03:52 PM
test for momentary switch + laptop cooling pad skeurton General Hardware Discussion 0 05-13-2004 10:11 PM
momentary switch skeurton General Hardware Discussion 2 05-06-2004 05:32 PM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
