Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 02-21-2008, 08:25 PM   #1
HELP! Did i just ruin my laptop!
well i had a nice power switch wired up so i could remove the laptop with ease but when i pulled it out today the actual chip for the power button came off. Here is a pic to show you, is there a way to fix this!
tacobandit is offline   Reply With Quote
Old 02-21-2008, 08:59 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Im pretty sure that isnt a chip. It is just a SMD push button. So just push it back on and solder it.
2k1Toaster is online now   Reply With Quote
Old 02-21-2008, 09:26 PM   #3
been trying that it doesnt want to solder back on!
Old 02-21-2008, 09:40 PM   #4
2k1Toaster's Avatar
You should be able to buy a new button board off of ebay before you replace the whole laptop if you cannot get it back on there.
Old 02-21-2008, 09:42 PM   #5
2k1Toaster's Avatar
I would check which pads are which with the buttons by measuring the resistivity between all the metal points, and when you get an open line, those are your contact points.
Put solder on those points. Put the button ontop of the solder. Then flash solder the button on from underneath both sides.
Old 02-21-2008, 10:03 PM   #6
okay well i bought a new button pad off ebay for 11 bucks so i will just hook that up. Sucks because i had it soldered up great. Guess i will have to just keep pushing it on when i get in
How can I use a laptop as a carpc? turbocad6 Laptops, Tablets, UPMCs, etc. 0 07-11-2007 01:55 AM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 02:18 AM
fix a broken dell laptop? kuo Off Topic 8 02-27-2006 05:58 PM
