The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 03-01-2008, 12:33 AM   #1
Vehicle: 2004 CHEVY MALIBU CLASSIC
My Photos: (1)
Newbie Question...
So i'm still debating between laptop and desktop, i've got a junkyard of both in my basement, well my parents but what's it matter. I've read the downsides of laptop and pros. Here is my main thing, I want to do this CarPC thing but I don't have a lot of free time, i'm always on the go, if i got a Laptop to do this, could i get most of the software stuff done on the go, or will a lot of it be fine tuning in the car?
Nickwell24 is offline   Reply With Quote
Sponsored Links
Old 03-01-2008, 02:21 AM   #2
Thefdog's CarPC Specs
Vehicle: 2002 Civic LX
My Photos: (0)
Software tuning is not that hard
1st. Get your hardware sorted out - What computer, what accessories, how are you going to mount it, how are you going to connect to your sound system
2nd. Play with the various front ends. Road Runner is one of the best, but it also takes a little tinkering to get it to work how you want
3rd. Set up your system in the house, with all peripherals attached, and get your front end working correctly
4th. Install in car and check if it all works. If not, repeat step 3. In this case, a laptop seems to be the simpler solution.
Cheers and good luck
Thefdog is offline   Reply With Quote
Old 03-01-2008, 02:08 PM   #3
My Photos: (1)
What are a good set of specs for a CarPC i see people running everything from 800 Mhz, to 2.5 Ghz, with 6Gb to 250Gb hard drive. I know for hard drive i'm looking run to around the 120-160 range because i've got more music than any man should. But I need advice on how many Hz i could get away w/. I am planning to run XP Pro, eventually have GPS and Wifi also.
Old 03-02-2008, 01:45 AM   #4
My Photos: (0)
Check out IBMs
I like the IBM series (older ones that is). They are built like tanks, are easily upgraded, and have cheap docking stations that allow you to take them in and out easily without having to disconnect anything.
I run a Pentium Mobile 1.6GHz, with 768MB ram, and a 80 gig drive (need more room though). If you are considering using this computer only in your car, I suggest you look at some of the small XP setups that are available. They pare down the installation to the minimum needed to run your carputer and speed boot time by getting rid of fluff you don't need. Search TinyXP to get some ideas.
These computers (r51) are pretty cheap right now - $400 or less on FleaBay and another $30-50 for a docking station. This is par with a mini-itx system and is far more versatile. I use my regular-use laptop for home, work, and carputin'
Cheers
Old 03-02-2008, 02:10 AM   #5
My Photos: (1)
It's actually funny you mention that laptop, i believe my dad has one laying around his house hidden somewhere in the basement from an old job. Only problem is it's burried in a basement which is from floor to ceiling... which means his power adapter is probably lost, do you know how well the AC/DC adapter for these computers would work for a CarPc?
Sponsored Links
vB code is On
Trackbacks are Off
Newbie question jaydm General Hardware Discussion 25 10-21-2006 10:07 AM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 06:24 PM
The Menu - A Newbie Question ( Sorry ) ccsnet FrodoPlayer 8 11-16-2004 01:09 PM
Newbie GPS question devin99 GPS 1 08-30-2004 02:50 PM
Stupid Newbie Question! robchopper50 MediaCar 2 03-06-2004 04:37 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
