Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Old 03-05-2008, 11:00 PM   #1
loopback adapter with relay
I'm using a loopback adapter with a relay to power on my eeepc. The adapter works just fine. If the relay is already energized and I touch the two leads of the ethernet cable to the relay it turns on just fine. But if I connect the leads with the relay not powered then power it on it does not turn on the pc. My theory, is that the electronic pulse created when I energize the relay is somehow interfering with the function. Does this make sense? Maybe I can use a transister instead or a diode protected relay. Any ideas?
chaos7692 is offline   Reply With Quote
Old 03-07-2008, 02:01 PM   #2
loop back...
What the hell are you talking about.. jk... ok how about a schematic?
pir8radio is offline   Reply With Quote
Old 03-09-2008, 04:45 PM   #3
Well, I figured it out. Turns out my wake on lan function does not work when using battery power. So I cracked open the eeepc and soldered two wires onto the power switch.
Old 03-11-2008, 12:48 PM   #4
ahh
ok i see where you where going now.. that was a good thought... I didn't see any mention about wake on lan, thats why i got a bit confused by the "loop back connector", anyway wake on lan looks for a special packet thats sent over the network, not a physical connection to the network.
StreetDeck Functions god_of_cpu DigitalMods (Scripts / API) 22 01-15-2008 10:44 PM
Will this work with an adapter? Rublex Newbie 4 05-31-2006 07:38 PM
Lock-start-puter circuit. KyleYankan Hardware Development 17 07-17-2005 12:05 PM
Alpine aux adapter issues oekundar Car Audio 0 11-22-2004 01:50 PM
slim slot dvd rom with wrong adapter, questions mattress General Hardware Discussion 3 10-24-2004 08:51 PM
