Quote: Originally Posted by
Nickwell24
what extra wires would i have to run for a relay? You said there are two extra wires, my guess would be Acc and Ign?
close
... one wire is a plain old ground (for the relay coil), the other is a switched power input (for the relay coil). the relay power input should be wired to the ACC
or the IGN circuit. the ACC circuit (first key position) is live when the key is in the 'ACC' or 'run' position. the IGN circuit is live only when the key is in the 'run' position.
a standard bosch-style relay has 4 or 5 leads. 86 is the coil power (from ACC or IGN line), 85 is coil ground, 30 is your PSU's power source (car battery), 87 is the switched output (87 and 30 are connected when the relay coil is powered). on 5-lead relays, 87a is the other side of the 'switch' (87a and 30 are connected when the coil is NOT powered. for your setup you have no need for 87a, so just leave it disconnected).
I think I remember from one of your other posts that you wanted to use a lighted switch. if that is the case, then it would only be 1 extra wire (since you would be wiring a ground wire anyways
Nickwell24
My main concern about a relay is where i'd put it....
a 30A relay is generally a 1 inch cube... that's it. even with the wires connected it's still only about the size of a single "C" cell battery. you can pretty much hide it anywhere
Nickwell24
Also with a relay when i turn my car off it sounds like the pc would turn off, unless i put an addition switch infront of the relay which would bypass the relay and direct signal directly to the pc.
with a desktop-type setup that would be true. but since you're using a laptop, it can run off it's own battery. when the relay switches off, the laptop will simply stop receiving power from the car's battery. it would continue to operate with it's own battery until you turn it off (or it's battery dies). if you want to continue powering it from the car's battery without the engine running, then you simply leave the key in the 'ACC' position
