Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Old 04-04-2008, 10:47 AM   #1
Wake on lan
Anyone used this to power up a laptop?
If so How did you implement it?
easy is offline   Reply With Quote
Old 04-04-2008, 10:51 AM   #2
Blaz3's Avatar
This explains WOL in detail: http://gsd.di.uminho.pt/jpo/software...i-howto-2.html
This pretty good tool i use for wake on LAN
http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx
Blaz3 [|||||||||-] 88%
Blaz3 is offline   Reply With Quote
Old 04-04-2008, 11:00 AM   #3
Thanks,
I know what WOL is I just wondered how you do it for a carpc?
is there a switch you can buy for powering it up from the lan socket?
Thats what I meant
From the sticky:
"one alternative to the power switch approach is a wake on ring or wake on lan type setup, but this only works on some boards & reliability can be a bit questionable, but if your dead set against opening the laptop this can be an area to explore."
Old 04-05-2008, 03:59 AM   #4
I couldnt find much info via search, was trying to implement wake on lan/link to my laptop, compaq v700 series..
no option in bios, but options on network card
found it only worked when supplied with ac power
but made a switch, maybe 3 feet long, off of a DIY rj45 loopback device, wiring pins 1 and 3 together and 2 and 6.. put a momentary switch between 1 and 3, couldnt get it to work longer than 3 feet, low power i presume.
looking for a momentary relay i guess itd be called..sense 12v power when i turn on key, complete that wire for a second and trigger laptop to fire.
frontier is offline   Reply With Quote
Old 04-05-2008, 06:53 PM   #5
wake on lan is actual data sent over the network. These Magic Packet frames are directed to a specific MAC address and are sent by another computer to wake a remote computer. You cant just put a switch or something on the network cable.
pir8radio is offline   Reply With Quote
Old 04-06-2008, 01:51 AM   #6
then I suppose my motherboard supports wake on link change or something of that sort
as the loopback device (google.com:loopback rj45) works flawlessly with a momentary switch between 1+3
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
New take on wake on lan? rniedzial General Hardware Discussion 0 08-29-2006 02:16 PM
Laptop powerup by wake on ring or wake on lan ZeroDefects Power Supplies 1 08-25-2005 10:01 AM
Will 802.11n support Wake On Lan? Danceheaven Wireless Communications 14 02-28-2005 11:19 PM
Wake Up Lan CorollaVerso'04 General Hardware Discussion 9 06-21-2004 08:43 AM
