The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 04-16-2008, 12:25 PM   #1
My Photos: (1)
What kind of switch should I buy?
Hi,
I'm soldering remote startbutton for my laptop. Only thing that I'm worrying is what kind of switch should I get?
Basically I would like to have switch with led light, so that I see that computer is powered and on. So it's same button as the laptop's own powerbutton is.
I'm just soldering two wires, and when switch makes connection laptop starts.
Red some posts, and someone was talking about momentary switch...
Jantsa is offline   Reply With Quote
Sponsored Links
Old 04-16-2008, 06:35 PM   #2
Vehicle: 2004 CHEVY MALIBU CLASSIC
My Photos: (1)
a momentary switch will be useful if you end up doing a mod like i am where i'm soldering my power button to my modem cable jack. Then i'm running the other end of the phone line and hooking it up to a momentary switch.
Planned ... 95%
Purchased 25%
Installed ... 0%
WorkLog
Nickwell24 is offline   Reply With Quote
Old 04-17-2008, 01:53 AM   #3
My Photos: (1)
Ok, so momentary switch it should be. I know the right pins, but led thing is weird. Original power switch has 6 different pins. They are numbered as 1,2,3,4,5,6. Numbers 1 and 2 makes computer to start. Then there is those 3,4,5 and 6.
Numbers 3 and 4 points to led on the switch, numbers 5 and 6 points to second led on the switch. If I want to have led in my switch, should I wire also 3 and 4 and put a led in the end?
Result would be, that I have 4 wires wired. Two wires goes to remote start, and two goes for the led. Why the hell there is two leds?
Here's pic:
http://www.mp3car.com/vbulletin/vbim...img&imgid=5297
Edit: and in the middle of the leds in the picture, there is a momentary switch.
Old 04-17-2008, 05:52 AM   #4
My Photos: (1)
I decided to take my laptop to the local electronics-shop. I get it back later today. They said that it's possible to take the original momentary switch away from the chip, solder new wires to chip, and solder original switch back to the end of wire.
That sounded great, because now I can use original cover from laptop, for my car's dashboard-mod. That's the way how I also get cool green led for my powerbutton
Hopefully they can do it without breaking anything. Guy in a shop said, that it could be hard if the original switch is glued to the chip.
Sponsored Links
vB code is On
Trackbacks are Off
M2 pic chip? can we program custom times? 89ragtopgt Power Supplies 7 01-22-2008 08:24 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 06:44 PM
Need wiring help for 2005 Grand Prix. derekmac Car Audio 33 09-21-2007 09:42 PM
Need help with X31 port replicator power switch viguera General Hardware Discussion 1 06-22-2005 11:12 AM
My idea for a Laptop Switch for my MKIV Jetta. Can this work?!? Man Ace Power Supplies 47 05-03-2005 12:28 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
