The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 04-20-2008, 05:37 PM   #1
panzermajier's CarPC Specs
Vehicle: 1999/chevy/lumina
My Photos: (0)
auto power on question
Hi everyone i have been lurking for a while now and this is my first post.I am workign on my third incanation of my carpc and I have a question about setting up an auto power on with a laptop. the laptop Im using has a regular spst toggle switch not the momentary puchbutton on most computers. My question is if there is a way to power on the laptop using the remote turn on wire from the car, and how I would go about hooking that up. Thanks, and if this question has already been asked please just redirect me to the thread I have not read to much but All the ones I have seen so far involve the momentary switch.
panzermajier is offline   Reply With Quote
Sponsored Links
Old 04-20-2008, 06:03 PM   #2
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
http://www.mp3car.com/vbulletin/user...rn-module.html
There's more out there too..................
Cheers
"That Others May Live"
It's not just a catchy slogan, It's my Job
greatwhite is offline   Reply With Quote
Old 04-20-2008, 07:11 PM   #3
My Photos: (0)
thank you for the link that is an interesting post however it seems that it will only work with momentary power switches not the toggle switch that i have
Old 04-20-2008, 07:29 PM   #4
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (50)
a laptop that uses a toggle switch??? I've never head of that before. I can imagine a slider switch or a rocker switch, but I'm having a hard time picturing a toggle switch on a laptop... what brand/model laptop is it?
you say that it is not a momentary switch, which would mean that the "toggle" stays in one position when the laptop is "on" and a different position when the laptop is "off" (in other words, the toggle doesn't spring back on it's own). if if truly is just a simple on/off toggle switch then then a simple SPST relay would work (but I have a hard time believing it would be that easy )
FusionFanatic is offline   Reply With Quote
Old 04-20-2008, 07:53 PM   #5
My Photos: (0)
the laptop is a old toshiba liberetto i believe. its a little compact touchscreen model with a celeron. im not sure if it is a toggle or slider switch but it works like a regular spst switch when it is down its off when it is up its on if i shut it down through windows and the switch remain in the on position i must move it to off and then to on again to start it up so idk if that makes a diffrence but the switch dose not spring back or anything like that and it turns the power off immediatley when switched down no interaction with the os. hopefully that clarifys what type of switch this is. if this relay will work is there any where online that i can learn how to implement it. thanks.
Old 04-20-2008, 09:12 PM   #6
My Photos: (50)
I looked at some pics of the Toshiba libretto series. I think I see the switch you're referring to on the front (under the 'pointstick'?). that's a slider switch, not a toggle switch; but they do the same thing anyways
the way you describe it, it's just a simple SPST switch (although it could also be a DPST, DPDT, etc. you won't know until you open it up and see). a relay will work the same as the laptop switch (a relay is a switch, it simply switches automatically instead of manually). hook the realy coil up to your car's ACC or IGN circuit, and hook the switch contacts to your laptop switch. you can buy a bosch-type SPST relay for about $5 at an electronics store (example; radio shack) or auto supply store (example; autozone, pepboys).
to wire a bosch-type relay: connect #86 to your car's IGN or ACC circuit (or any other switched 12vdc source), #85 to chassis ground, #30 to one side of your laptop switch, and #87 to the other side of your laptop switch... like this:
you should hook up another relay to your laptop's power supply, this will cut power when the car is off (to keep you from waking up to a dead battery in the morning ) I wrote a simple guide to relays in the FAQ emporium in this forum.
Old 04-21-2008, 07:59 AM   #7
My Photos: (0)
thanks alot. That is very detailed and should be all i need to get this going.
Sponsored Links
vB code is On
Trackbacks are Off
Hardware Review: M3-ATX Power Suply Bimmerstyle The Review Palace 8 03-05-2008 05:57 PM
Question about Laptop Power on/off ashiq32 Laptops, Tablets, UPMCs, etc. 1 02-01-2007 08:11 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
power supply question? pimpmode Power Supplies 3 03-23-2005 04:42 PM
Noob question about power supplies Jagojon3 Newbie 10 03-08-2005 11:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
