The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 05-09-2008, 01:38 PM   #1
My Photos: (0)
Toshiba M35X laptop
I've got my old Toshiba laptop kicking around doing nothing but collecting dust.
I've searched the forums and haven't found anyone that is using a Toshiba laptop in for a carpc. Did I miss some?
I'm leaning towards putting it under my passenger seat and hooking up a touch screen in my dash.
I haven't seen any good pictures of hooking the power to the modem. I'm good with computers but not good with other electronic stuff. Is there a 'how to' guide some where that I can look at? or did I miss it?
Great site, lots of information.
Edit: Oh yea, this would be going in a 2005 Xterra.
Thanks.
cornick is offline   Reply With Quote
Sponsored Links
Old 05-11-2008, 08:32 AM   #2
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (50)
Quote: Originally Posted by cornick View Post
I've got my old Toshiba laptop kicking around doing nothing but collecting dust. ~ I've searched the forums and haven't found anyone that is using a Toshiba laptop in for a carpc. Did I miss some?
the laptop brand/model doesn't really matter unless there is something about it that is significantly different from other laptops. otherwise it doesn't matter if they are a toshiba, dell, sony, acer, etc. etc... they all hook up the same.
you don't hook up "power to the modem"... I assume you are referring to using the modem jack as a connector for a remote power switch?
you'll have to solder two thin wires onto the motherboard power switch/button leads (use a jumper wire or a multimeter to find out which leads to solder). then run those wires to your jack. on the other side of the connector (that plugs into your jack) you would hook up a momentary power switch.
personally, I would use a new jack (like a mini [headphone] jack or small barrel plug jack) and drill a hole in an unused space on the side of the laptop somewhere to mount it. but if you want to use the modem jack then that's fine as well. most laptops use a separate 'daughter board' for the modem/LAN jacks. you'll need to disassemble your laptop to access it. cut the wires (or circuitboard traces) that lead to the pins on the modem jack that you want to use.
NOTE: if they make a docking station for your laptop that has a power button on it, then it may be much easier to wire a remote switch to that instead of hacking your laptop
FusionFanatic is offline   Reply With Quote
Old 05-12-2008, 12:13 PM   #3
My Photos: (0)
No docking station for this laptop, at least that I can find.
Sorry about the confusion on the power, I guess I need to reread what I found.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
