Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Old 06-20-2008, 10:26 AM   #1
Contant Power Cigarette Adapter
Hello.
In my Jetta 2006 cigarette adpter stays on even if the car is turned off. I am using a laptop and DC car charger for it. I have laptop in trunk along with amplifier. Last night I spliced the back of cigarette adapter in my car. I programmed it with Remote cable from amp, and it smoked the ***** out of my car. However car works fine. My question is that is there a way to have the cigarette lighter turn on only when the car is on?
d3siboy is offline   Reply With Quote
Old 06-20-2008, 12:07 PM   #2
yes, remove the 12v power line from its source and connect it to the accessory line.
trover4 is offline   Reply With Quote
Old 06-20-2008, 12:12 PM   #3
i m sorry but could you tell me what do u mean by accessory line? thnc
Old 06-20-2008, 02:59 PM   #4
Ok I found that Accessory wire is same as remote wire. However I brought another connection from an amp ti cig adapter and it resulted into smoke. Please see the picture for more info. Could tell me why would it turn into smoke. Smoke was coming from dash, where amp remote wire connects to car's acc wire.
Old 06-20-2008, 10:07 PM   #5
The accessory wire is not meant to carry power...its more of a signal wire. If you are lucky, you might have just blew a fuse somewhere in your fuse box. If you still want to go ahead and do the cigarette power mod, use a relay.
nobb is offline   Reply With Quote
Old 06-21-2008, 12:26 AM   #6
nobb thanks for the reply. Do you have link or information on how to relay cigarette adapter? Thanks
Old 06-21-2008, 03:38 AM   #7
Raw Wave
Rob Withey's Avatar
The bit that worries me is that your diagram has permanent 12v and the remote line going to the cig adapter. How did you wire that up?
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 06-21-2008, 09:34 AM   #8
OK so initialy there was 2 wires in back of cig . one pos and one neg. so i spliced them and connected neg with remote wire from amp. Positive with harge remains the same.
Old 06-21-2008, 10:15 AM   #9
Raw Wave
Rob Withey's Avatar
So let me get this straight. You shorted your remote wire to ground and left the positive alone?
Oh boy...!
Old 06-21-2008, 06:09 PM   #10
Yeah not good, the remote line is giving a switched +12V that activates when the radio is on.
What you should have done was with the help of a switched source, in this case the remote wire, with use a relay to interrupt the +12V wire of the cig lighter when the radio is off and trigger the cig lighter to activate when the radio is on. With the relay you want to wire it up to these terminals of the relay to the respective wire:
85 - remote wire
86 - ground
87a- not connected
87 - cig lighter wire +12V from car
30 - Cig lighter wire to the cig lighter
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 06-21-2008, 11:25 PM   #11
Thank YOu So Much. It actually worked with relay. THanks again.
Universal adapter power options? g099521 Laptops, Tablets, UPMCs, etc. 2 06-05-2008 01:28 AM
Lilliput 629GL power? IceX LCD/Display 1 02-13-2008 04:09 PM
Question about Cigarette Lighter for power. ninvertigo General Hardware Discussion 8 09-18-2007 08:51 PM
lilliput without a power adapter? killahkosha LCD/Display 1 09-06-2006 10:48 PM
Can a P4 e-PC be powered by a cigarette lighter power? BlackAWD Power Supplies 5 10-04-2005 03:54 AM
