The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 03-29-2005, 12:35 PM   #1
Vehicle: 2001 Nissan Maxima
My Photos: (0)
Shutdown Controller and Laptops
Can someone explain how I would wire up one of those shutdown controllers to send my laptop into hibernation (i.e. wired to the power button on my laptop and or a docking station)?
I was thinking about using the uSDC20D micro Shutdown Controller. I understand that a wire has to go to ground, another wire has to go to the ignition, and another wire has to go to the car battery (positive).
The part that is confusing is how to wire it to the power button on the laptop when the controller is made for ATX computer/power-supply.
blackflux is offline   Reply With Quote
Sponsored Links
Old 03-29-2005, 03:06 PM   #2
Rich Creamy Center
Vehicle: 1991/Citroen AX GT/VTS conversion
My Photos: (0)
take apart your laptop apart and wire it in parrarel to the button that turns your laptop on
So far - 1.1ghz athlon 4 Sharp Laptop, 256mb RAM, 20GB HDD, 32MB on board graphics. CDRW/DVD, 600W Boschmann amp, K301 InDash Screen
Ryanmt is offline   Reply With Quote
Old 03-29-2005, 05:25 PM   #3
moahdib's Avatar
Vehicle: Acura TL 2004
My Photos: (0)
the power button for a standard ATX mobo shoudl be the same for laptops. At least it is the same on mine.
Check my sig below and go to post #52. I have some pics of the uSDC20D controller hooked up to my dell laptop with docking station.
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 03-29-2005, 05:33 PM   #4
Vehicle: 1994/Ford/Probe GT
My Photos: (0)
I have a Sony laptop and a Dell and neither of them have jumper-style pins like an atx motherboard, just pads that the button is soldered to. I ended up using the Dell in the car and had to solder wires to the pads and extend them outside of the laptop case to hook up to my shutdown controller.
So, to the original poster, you have to take it apart and look where the power button is hooked up to. If it's just pins then you lucked out and you can hook it up to that, otherwise you might have to do some soldering.
There are also shutdown controllers available that can shutdown via the serial port and some software (eg. DSSC), but these I don't think there is a startup option when you use it like that so you will have to setup the laptop BIOS to resume on power loss (if it has that option in BIOS).
Bobby Digital is offline   Reply With Quote
Old 03-29-2005, 09:09 PM   #5
My Photos: (0)
Thanks people. Since I have a docking station I can solder the controller to the power button on that. But that's not really an issue, I am more concerned about wiring it correctly and that it (uSDC20D) will actually work.
So with that said what's the best controller to get to use with a laptop?
Old 03-29-2005, 11:46 PM   #6
LinuxRacr's CarPC Specs
LinuxRacr's Avatar
Vehicle: 01 Turbo Mazda MP3
My Photos: (0)
I want to know as well. I have a HP Pavilion N5190 Laptop with docking station for my project. I am almost done, and this is one of the final touches to complete my project.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Starting over again with new build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 03-30-2005, 12:36 PM   #7
LinuxRacr's Avatar
My Photos: (0)
I guess I will need to take one of my docking stations apart to see what's what.
Old 03-30-2005, 01:02 PM   #8
My Photos: (0)
Our shutdown controller will do serial port shutdown, so you don't need to open the laptop. When using serial port shutdown, you do have to turn on the PC by yourself though.
Check it out, it is so much more than just a simple shutdown controller.
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
KyferEz is offline   Reply With Quote
Old 03-31-2005, 07:53 AM   #9
My Photos: (0)
Whichever controller I use has to be able to startup the laptop. I just wish I knew more about electronics...
Old 03-31-2005, 09:31 AM   #10
My Photos: (0)
Well, our controllers can fully control a laptop, however, you will have to connect to the laptop's pushbutton. Likely this will require soldering wires onto the pins of that pushbutton.
KyferEz
Copper Wire Data
Sponsored Links
Old 03-31-2005, 12:13 PM   #11
My Photos: (0)
Are there any concerns with laptops and cranking your car?
Old 03-31-2005, 12:27 PM   #12
My Photos: (0)
If the laptop has a battery installed, cranking should not be an issue (it would be like pulling the plug for a second then plugging it back in).
As for wiring, it's pretty simple. Here's what you'll have to hook up for MOST shutdown controllers (read the instructions for your SDC carefully first!):
-constant power IN, should be directly from the battery
-switched power IN, eg. the ACC line, this tells the controller when to send the on/off pulses to the power button
-ground
-power OUT, this will be going to your inverter so that your laptop can be charged by the inverter
-(may or may not be) ground "OUT" for the inverter, you may also just ground the inverter to the chassis (remember to use a single ground point for everything)
-2 pins for your ATX switch, these go to the power button that you've soldered on to, polarity should not matter so either pin goes to either pad on the button
Hope that makes sense and helps you a bit.
Old 03-31-2005, 01:10 PM   #13
My Photos: (0)
thanks!
Old 03-31-2005, 02:10 PM   #14
LinuxRacr's Avatar
My Photos: (0)
Ok, so what if my battery cannot hold a charge anylonger, and I can't buy a new one right now?
Old 03-31-2005, 03:19 PM   #15
My Photos: (0)
It may not be an issue if you are using an inverter. If it is, you could use our tank circuit with a sealed lead acid battery.
KyferEz
Copper Wire Data
Sponsored Links
vB code is On
Trackbacks are Off
Laptop Startup/Shutdown controller jonee Power Supplies 25 04-05-2005 08:50 AM
Controller + inverter for Toshiba LTM10C321A? Arathranar LCD/Display 0 10-05-2004 06:28 PM
Startup pulse fix with Jeff Shutdown Controller moahdib Power Supplies 2 03-03-2004 11:51 AM
Need an LCD controller for ex laptop display MGP3Car LCD/Display 2 08-31-2003 06:14 AM
latop lcd screen with controller card? schrodos General Hardware Discussion 3 11-20-2000 10:34 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
