Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 11-20-2005, 02:35 AM   #1
Any downsides to a laptop car adapter as a power source?
I did a but could find no answer to this question...
I have a P4M laptop with a 16V 4.5A power source and I can find various power adapters that are suitable for it's use in a car straight from a cigarette lighter.
I am wondering are there any downsides to using one of these devices - for example - is the power it delivers well regulated? Does anyone have any favourite brands? Does it wreck the laptop battery?
Any help would be greatly appreciated!
Thanks!
BlackAWD is offline   Reply With Quote
Old 11-20-2005, 03:04 AM   #2
arebelspy's Avatar
That should be fine.. powering a regular computer through an inverter runnign from the cig lighter = no no, could start a fire. But the amount of power a laptop will draw is so little and the wattage on the adapter should be fine to run from the cig lighter.
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
arebelspy is offline   Reply With Quote
Old 11-20-2005, 03:36 AM   #3
Thank you for your reply... but I am talking of a gadget that takes the 12V DC and changes it to 16V DC - as far as I know this is NOT an inverter - I am not going though any 240V AC change...
So are you still talking about the same thing Arebelspy?
Old 11-20-2005, 07:16 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
Yes, he's talking about the same thing.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-20-2005, 08:21 AM   #5
I have been using one of these for 6 months:
http://www.powerstream.com/ADC.htm
I haven't seen any significant decrease in laptop battery capacity.
They seem to be pretty reliable.
jayearl is offline   Reply With Quote
Old 11-20-2005, 08:25 AM   #6
Fox_Mulder's Avatar
I have a Targus Car/Laptop adaptor, works fine!
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Old 11-20-2005, 03:10 PM   #7
arebelspy's Avatar
Thanks Darque.
Yeah, I meant in general the advice is don't power anything from a cig lighter. For example, a regular comp running off an inverter, the inverter should be wired directly to the battery, running off the cig lighter can start a fire.
In your case "the amount of power a laptop will draw is so little and the wattage on the adapter should be fine to run from the cig lighter" - it's designed for it, in fact.
-arebelspy
Old 11-20-2005, 03:40 PM   #8
Thank you all for your help - this is good - I can start work on it straight away...I can wire a similar thing to the screen...
Just out of interest, has anyone checked how much the voltage output fluctuates in these devices?
Old 11-20-2005, 04:44 PM   #9
arebelspy's Avatar
Probably not a good idea.. running too many things from the cig lighter is what I was trying to caution you on.
-arebelspy
Old 11-20-2005, 06:59 PM   #10
Fox_Mulder's Avatar
I don't think the voltage would fluctuate that much if at all, as it has to feed a well regulated supply voltage to your expensive laptop.
Fox Mulder
2004 Toyota MR2
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 01:41 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 08:58 AM
Audio hum in car using AC-DC Power adapter. djdafreund Power Supplies 8 03-15-2005 10:07 AM
Here's an alternative power source.... A Boy and his Miata General Hardware Discussion 7 11-21-2000 12:44 PM
