Quote: Originally Posted by Stevo759
and it wouldnt hurt the circut board to solder to thoes diny little connections?
Thanks for the quick responses guys!
Post a pic, that would help tremendously, BUT, in general NO, it will not harm the circuit board, how do you think they attach the components on the board??
Just make sure too not overheat anything. That is why it was suggested that you use the soldering iron by touching the switch, and removing it, increasing the time until the wire stays there. Also, try and use a low wattage iron, say 15 watts or so. Besides, the larger ones (25 watts and up) usually don't come with fine tips, because they are too strong for that.
Michael
