Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 02-20-2006, 03:48 PM   #1
XJE
n00b question about laptops as carputers
I tried searching for this topic for a bit, and I came up with a lot about using a laptop as a carputer, but I wasn't able to find the answer I needed. Since this is probably a common question, I'll apologise in advance.
I've got a really nice laptop, an Alienware M7700. I thought about using a separate system for my carputer, but why waste the extra money, when I've got a better system right here, eh?
Anyway, since it basically IS my desktop, and I'll just be unhooking it (takes just a few seconds with my setup) and sliding it into a docking station under the seat, I'm not sure what to do software-wise.
Is it possible for me to set up a separate profile that'll activate when I put it in the car, or at least one I can select? I have an idea of how it could work, but a few experienced heads would really help point me in the right direction.
XJE is offline   Reply With Quote
Old 02-20-2006, 04:13 PM   #2
randomjohn's Avatar
I assume you're running Windows XP (if you were running Linux you wouldn't be asking this question, and that's what your laptop shipped with anyway). If so, you can just create a separate user account with the different startup options you want. You'd have to pick (and enter the password) whichever account you wanted, but it's a fairly simple process. Tell us what differences you'd want between the two environments. The other end of the complexity spectrum is setting up dual boots, which is basically like having two entirely separate computers residing in one box. For example, I (like many people) have a computer that boots up giving me the choice of going into windows or linux, and neither really knows the other is there.
GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
Worklog: http://www.mp3car.com/vbulletin/worklogs/65059-03-jetta-if-i-can-any-idiot-can.html
Now with pictures!
randomjohn is offline   Reply With Quote
Old 02-20-2006, 04:54 PM   #3
noreason's Avatar
I was going to suggest the same thing, but I dont think you have to use a password do you? It would make it alot easier assuming your not going to use a keyboard.
1997 Saturn SL2 Car PC Status [..........] 0% Complete (Removed)
1999 Honda Accord Car PC Status [::::::::..] 80% Complete (Setting up software before final install)
noreason is offline   Reply With Quote
Old 02-20-2006, 05:32 PM   #4
XJE
Yes, I am running Windows XP. I'm pretty sure I can setup a second account without a password.
Really, what I'd just like is for that second environment to startup in, I guess, Carputer mode. I've seen a couple different programs around here that offer a visually-based frontend designed to be used with a touchscreen, but being pretty new to the process, I haven't dug very deeply. Would I just make a second account, and then install the frontend program so that it boots on startup? That just seems like it would be... well... too easy, you know?
The way it'll be setup, all the extra jazz, such as the amp hookup, the gps system, and things of that ilk will hook directly into the dock, so the connection process is swift and painless. I just need a setup that will recognize that hardware, so that my regular setup doesn't always freak out over "missing hardware" when it's not in the car.
Does that help?
Thanks for answering, by the way.
Old 02-20-2006, 05:47 PM   #5
noreason's Avatar
Creating a second account will do all of this for you. Just install the hardware and software on the second account and put whatever front end your using in the auto start folder... Start>Programs>Startup.
When the system boots you will be prompted with the user selection login screen where you just click the user account you want to load. Click the "Carputer" account and boom, windows will finish loading up and auto start centrafuse or whatever frontend you decide to go with.
This is a simple and effective route, the only thing is that bootup wont be seamless you will have to touch the screen (or mouse) to click the user account to load it. But it really is no big deal, i have to do it too and it doesnt bother me at all, it lets me know my touchscreen is still working!
Old 02-20-2006, 05:52 PM   #6
XJE
Wow, that's, um, really simple.
Here I was, thinking there would be a lot more to it.
Thanks a lot, guys!
I'll be sure to post pictures once I get everything installed. Should look interesting mounted in a '69 El Camino.
Old 02-20-2006, 06:01 PM   #7
noreason's Avatar
Thanks a lot, guys!
Keep us posted
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 07:24 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
question about touchscreens, and interesting device found yalborap General Hardware Discussion 10 02-09-2005 09:18 AM
n00b question stillnocar Car Audio 1 12-30-2004 10:25 PM
lcd power question jrbless LCD/Display 1 04-07-2002 01:27 PM
