Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Old 05-07-2006, 09:15 AM   #1
Running M2-ATX with a Laptop
Hey, I'm new here, but not new to CarPC's. However my project this time around is going to be based off a laptop rather than a box.
I know a few of you guys have messed around with the M1/M2 power supplies maybe you can answer a few questions for me.
First off, if you're wondering why I need a M2-ATX for a laptop...its to run the LCD, external HDD, and some power hungry USB devices(namely Audigy2 NX USB & USB powered DVDRW drive). I'm also going to solder a wire to the power switch of the laptop and run that to the J8 of the M2.
Anyways my question is, will the M2 unit have power output thru the 3.3,5,12v rails with only the car ACC on? Or does there need to be a motherboard connected and powered on for those power rails to come on. In my situation, there is no ATX board to hook into since I'm running the laptop.
JeffTsai is offline   Reply With Quote
Old 05-07-2006, 09:32 AM   #2
Sidewalksalvage's Avatar
As is, no. There is one wire on the ATX connector that needs to be shorted for it to believe the PC is on. On the connector the green wire must be connected to the ground for the whole board to operate properly. As long as this point is grounded, the board will completely operate.
The J8 connector probably will not do much. Its probably a better idea to use a relay with the USB off the laptop. The USB 5v line will turn the relay on which will short the green wire.
Good luck
-Luke
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 05-07-2006, 09:45 AM   #3
Running the relay from usb power to the atx green wire makes sense.
lol...didn't even think of that one. Thanks for the suggestion.
I might buy a M2 just to test out, and that I will need it anways for my project. Any of you guys here try jumping the atx green wire to see if the 3.3,5,12v will power on?
Old 05-07-2006, 11:30 AM   #4
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Check out my sig :-)
W3bMa5t3r is offline   Reply With Quote
Old 05-07-2006, 02:38 PM   #5
Cant take full cred...thats where i got the idea from........
Current Progress:
Brown 2010
Old 05-07-2006, 02:51 PM   #6
MikeH's Avatar
JeffTsai
You may want to take a look at the P1900. It should work well for you laptop application depending upon what voltage your laptop requires.
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
why does my laptop turn on? Efess Laptops, Tablets, UPMCs, etc. 19 07-02-2007 08:45 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Laptop for carputer project airborne_cookie Newbie 13 05-31-2005 10:23 AM
Shutdown/Startup Controller for laptop JoyRidun General Hardware Discussion 24 07-01-2004 06:08 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
