Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 05-14-2006, 10:26 PM   #1
If you are a laptop expert or technician, PLEASE read.
Hi guys. Sorry to bug everyone again, but I've found myself in a pretty big problem. I have a Gateway 7405 gx laptop that has been shutting down randomly. It seems to be a heat issue, so I did what any logical person would do. I ripped the case of the laptop open so I could blow out the fans and clean the heatsinks. Wonderful idea, huh?
It's not the worst Idea ever. I tore apart my old sony laptop after it was broken, so I've got a relatively good idea of what to do and where stuff goes.
I tried to enter the case from the bottom, took out all the screws and tried to gently pull the case apart to access the internals. This did not work. Screws on the top were holding it together. Duh, I know this from last time. I remove the power strip panel and keyboard from the top. No big deal. I then remove a silver support panel that was under the keyboard.
Alas, I have internals. I take out my Can-o-Air and spray the fans, heatsinks, and wipe down the heat pipes by the processor and GPU. Everything's looking good. I reassemble everything in reverse order. I had a small issue re-attaching the connecting ribbon cable between the power button strip and the motherboard, but I assume I solved that because the power button works.
I reinstalled the battery, dvd-rw, ram, everything I took out. No big deal. Everything's going fine.
Go to power on the laptop to enjoy the fruits of my labor ...(yeah, this is where it gets good).
Now all of a sudden, it won't boot. What it does is this:
1. Press power button, power button illuminates and system sounds as if it were powering up. Blue "ON" light on the front of the case also illuminates.
2. Hard drive spins up, and dvd-rw checks for any bootable media, numlock and caps lock LEDs flick on for a second.
3. Numlock and Caps lock LEDS go off for 2 seconds.
4. Repeat steps 2-3
Also, to turn the laptop off, I have to press and hold the power button for 5-6 seconds, instead of just a quick press, which indicates to me something's going on... but it sounds like it's repeating the first stages of boot over and over.
So, I guess my question is this... What would cause this? Laptop worked 5 minutes prior to disassembly (not counting it getting hot and shutting down), so hardware failure is probably not the cause. Is there something loose? After it didn't boot the first time, I disassembled and reassembled the entire system to check my connections. Still the same symptoms.
Do I have any options short of paying a technician to take a looksie?
My warranty is up, I'm unemployed (livin off my nest egg), and probably screwed. Please don't tell me that I shouldn't have opened my laptop up if I wasn't able to afford breaking it... I know, but I've done stupider things
Any help rendered here will be greatly appreciated.
Thanks in advance
-dan
WoLLy is offline   Reply With Quote
Old 05-14-2006, 11:32 PM   #2
avengerki's Avatar
Sounds like you got a loose connection somewhere. That cable you mentioned between the power strip and the mobo would sound like a good place to start. Do you get any video or just it hear everything going on?
Avengerki
Progress: 98%
Car PC: Dual PIII 1ghz w/ 1GB Ram
Need a credit card?
avengerki is offline   Reply With Quote
Old 05-15-2006, 11:46 AM   #3
No video, just sounds. That ribbon cable just connects the piece above the keyboard that controls power on, volume up/down, and loads IE, to the motherboard. It's the equivelant of a lilliput front panel control setup.
I would think that if It's recieving the power-on signal, it'd be secured correctly. I'll try re-seating it (although the mobo side was very difficult, took almost an hour)
Old 05-15-2006, 12:16 PM   #4
Laptop, Tablets, UMPC Moderator
turbocad6's Avatar
is this a p4m laptop? this is what usually happens with them when they overheat... toasting the main board...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 05-15-2006, 01:12 PM   #5
No, it's an a64 3200 system and the system was perfectly fine prior to disassembly, so I doubt it's a hardware issue. I'm wondering if something simple jiggled loose or something.
Old 05-15-2006, 02:08 PM   #6
turbocad6's Avatar
sometimes the case screws hold certain connections togeather, mostly 2 components grounding to each other & a loose screw can cause a bad connection.....
either that or don't assume because the power button works the whole ribbon is ok.... try reseating it.... is it damaged?
Old 05-15-2006, 02:18 PM   #7
avengerki's Avatar
Thats what I was refering to. its possible with those ribbon cables to have them where it will half function.
Avengerki
Progress: 98%
Need a credit card?
Old 05-15-2006, 03:41 PM   #8
Laptop is at local shop being diagnosed today. We'll see how this goes. I can't handle any more **** right now.
Old 05-15-2006, 03:46 PM   #9
You say the system was totally fine before you took it apart but in your first post, you say it was shutting down randomly. maybe it could be the same problem? A hard drive going bad maybe? sometimes taking it apart and putting it back together can be just enough to kick it.
Vinister is offline   Reply With Quote
Old 05-15-2006, 06:21 PM   #10
It was apparently a heat issue, would only shut down when playing halflife 2 or unreal 2004... and then it would only happen a few seconds after the primary fan switches on full blast.
The symptoms make it seem doubtful that a hard drive or ram is bad. I figure something jiggled loose or something that I didn't know about.
Old 05-15-2006, 08:55 PM   #11
fooshizn1x's Avatar
check them pesky flat cables, I dont remember wtf theyre called.. but they are the kind where you slide the connector open a tad and then the cable comes out.. one of those may have come loose.. also maybe see if there is a cmos reset jumper.. that may help.. or unplug the cmos battery for 10 minutes and plug it back in.
Sell me your stuff.. please see what i'm looking to buy
http://mp3car.com/vbulletin/showthread.php?t=75182
fooshizn1x is offline   Reply With Quote
Old 05-16-2006, 10:05 AM   #12
If the shop can't figure things out, I'll make sure to give that a shto. Thanks foosh.
Old 05-20-2006, 12:22 AM   #13
Grimoire's Avatar
Was it figured out?
To me, It sounds like you may have a power button pushed down. You push it in, and it stays in, or partially in because after what 4 or 5 seconds, it shuts off then starts back up. Sounds like the power button is holding down, then its comming back up, shutting down, comming back up. Take off the power strip and make sure that the power button is free moving. Also, yes, check cables. I know that the stupid clips they have are tiny and you need the smalles screwdriver known to man to use em. They also slip out so use tweezers! >.<
Grimoire is offline   Reply With Quote
Old 05-20-2006, 10:13 AM   #14
The most reputable local shop thinks my motherboard is fried. I'm considering now either parting out the screen, keyboard, 80 gb laptop hdd, slimline dvd-rw, and ram... or there's a service on ebay that says motherboards arent usually dead, they're fixable, and you send your laptop to them and they fix it for 185 bucks. If they cant fix it, you pay nothing. Guy has huge feedback and is always selling lots of laptop specific parts.
I'm definitely intrigued.
Old 05-22-2006, 07:00 PM   #15
turbocad6's Avatar
my first thought was a toasted board....the p4m's were notorious for this, but others are affected by this too.... NEVER USE A LAPTOP ON A BED!!! this is usually what overheats them....
sorry to hear that.... I'd be very liery about fixing it.... if you can find a replacement board then maybe, but most of the times it isn't worth it....
Remote laptop startup ambush Laptops, Tablets, UPMCs, etc. 47 11-24-2008 03:28 AM
Made permanent damage with dc-dc adapter for laptop?! help! diskey Power Supplies 16 04-29-2006 09:03 PM
Dell Laptop + Docking + Great Condition + LIGHT! FiReBReTHa Classified Archive 4 03-08-2006 02:48 PM
fix a broken dell laptop? kuo Off Topic 8 02-27-2006 05:58 PM
FS: Toshiba Laptop 1.3GHz/15.4" WS/60GB/512MB/802.11g migel628 Classified Archive 22 09-18-2005 12:15 AM
