06-29-2006, 11:55 PM
#1
Laptop Wont Power up with screen down
I have a dell 5100, did the mod so i have an external momentary switch(and relay setup) the only problem is that the computer refuses to power on with the screen closed! There is no ovbious sensor to obliterate.
any ideas?
cheers
98 V6 Camry XLE
Status-Who Knows
Just Finished:Dual Battery Setup
Next Stage:1/2 Din Faceplate
Ze Worklog
06-30-2006, 12:02 AM
#2
Laptop, Tablets, UMPC Moderator
there should be a tiny little plunger up twards the hinge side of the base.... just a tiny pin..... if you shave it down the laptop will never know if it's opened or closed.... it would be a little more difficult to interupt it with like a toggle so you can decide how you want it to work at different times...
06-30-2006, 12:05 AM
#3
Neither darque nor pervert
There shoudl also be a setting in the BIOS and/or the Windows power management settings about how you want the laptop to react to closing the lid.
You want it to do nothing.
My Worklog
06-30-2006, 12:06 AM
#4
yeah, that too
06-30-2006, 12:09 AM
#5
but that is only for when its running. It wont let me come out of standby or being off with the lid closed, which makes sense to prevent accidental turn on. but im a little more  then that
98 V6 Camry XLE
Status-Who Knows
Ze Worklog
06-30-2006, 12:38 AM
#6
I saw sensor & obliterate in the same sentance, so I figured you were after the hardware more really
also I said it won't know if it's opened or closed, that's WRONG... I ment it'll always think it's open...
06-30-2006, 12:41 AM
#7
yea. I looked at the computer and couldnt find a button. i read somewhere that mabye it was magnetic. ugh
98 V6 Camry XLE
Status-Who Knows
Ze Worklog
06-30-2006, 12:56 AM
#8
RoadRunner Mastermind
Most Dell laptops have a little pin by the power button that is pressed the the screen goes down (I've had 3 of them), in such case you can simply pull the panel above the keyboard out and disconnect the sensor if you like. Even if the sensor is different, you can probably do something similar w/ most Dell laptops even if it's a different type of sensor. The only side effect is that you won't be able to configure the computer to standby/etc when closing the screen.
Road Runner RR's Myspace
06-30-2006, 01:13 AM
#9
If you were adventurous enough to open the unit to install a momentary switch for power...i bet you could do it again to can the lid switch.
It is either magnetic or push based, either way its gunna be coneccted to the board via some kind of wire and pin connector. I say open it up, find the switch follow the lead and pop it out. (you can leave the hardware in just dissconnect it)
Your hardest problem will be if its hard soldered to the board...but i think again if you soldered a momentary switch in, you will be able to unsolder the unit off.
I dont like the idea of cutting down the switch cuz if you ever DO need it again, and hell you never know... you dont have any easy way of getting it back. by unplugging / unsoldering, you can always reverse your actions.
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
06-30-2006, 01:22 AM
#10
I really have no problem doing the dirty work, its just i have no idea where the switch is. i guess ill look closer tomoz
98 V6 Camry XLE
Status-Who Knows
Ze Worklog
#11
yeah, I'd probably want to keep it reversable really too...
06-30-2006, 01:24 AM
#12
I've seen some with a micro switch at the latch, but I thought all dells had the little pin switch??
if you can't find anything in the base it may be in the bezel?
06-30-2006, 04:44 PM
#13
Most dells i have seen have a pin switch...however it could be magnetic or it could be a pin switch inside the bezel and or hinge.
Current Progress:
Brown 2010
06-30-2006, 04:47 PM
#14
ive removed anything in the hinge. ill look at it a little later. mabye put some hi res pics up
98 V6 Camry XLE
Status-Who Knows
Ze Worklog
| Thread Tools |
| Display Modes |
Linear Mode
