Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Old 10-02-2006, 11:42 PM   #1
seakykr's Avatar
Touch screens work with laptops?
Do the kinds of touch screens you guys use (Lilliput, Xenarc, DWW, etc.) generally work if attached to a laptop computer, or are they designed more for custom car pc computers? Maybe a stupid question, but one of the basic things I haven't found covered in the FAQ's. Thanks.
seakykr is offline   Reply With Quote
Old 10-03-2006, 12:03 AM   #2
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
My Lilli was setup first on my laptop, then on my desktop and then back to my laptop used for the carpc.. a monitor is a monitor for the most part. They 'typically' aren't for 'custom' setups, but most of us use them in that fashion
W3bMa5t3r is offline   Reply With Quote
Old 10-03-2006, 02:48 AM   #3
DigitalDub's Avatar
Yep, I use a LinITX touchscreen with my laptop. Just another monitor as far as the machine is concerned. The touchscreen will be supplied with drivers that allow the touch part of it to work.
You may need to make a BIOS or Windows configuration change to tell the laptop to output to an external monitor.
D.
DigitalDub is offline   Reply With Quote
Old 10-03-2006, 12:27 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Short answer is yes.
Longer answer is, there are two pieces to a touchscreen monitor. They actually operate independently. First, the monitor. If your laptop works with an external VGA monitor, you can use a Lili or Xenarc, etc.
The second screen is the touch screen. This is a glass overlay with pressure sensitive film that is included with monitors labelled as "touchscreen". It comes built in to the monitor and commonly hooks up to the computer using a USB connection. You load a driver and it generally works fine.
I've not heard of reports of any laptops that won't work with touchscreens, however, you'll need to either make the touchscreen monitor the main display or mirror your laptop display to it. Otherwise, you won't be able to control the OS because you won't be able to touch the bits you want to select.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is online now   Reply With Quote
how can i setup two touch screens w/different outputs?!?!?! afterdigital LCD/Display 3 09-20-2006 07:23 PM
Flip down TOUCH screens??? jparks27 LCD/Display 8 07-01-2006 02:31 PM
using touch screen's robert42 ME Archive 7 09-10-2003 07:10 PM
for those with touch screens... Dragyn General Hardware Discussion 9 03-07-2001 09:04 PM
12volt & $300 touch screens katnip General Hardware Discussion 4 09-11-2000 01:22 PM
