The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 10-15-2006, 12:09 PM   #1
My Photos: (0)
Turning on laptop...this has been discussed
I know there has been millions have threads on turning on a laptop, and I have probably read alot of them. I don't want to mess with wake on lan, wake on ring, I dont have UPS power on resume for my laptop, and I cant just solder on an external swith because the button manually presses down on a mechanism instead of an electical signal through a wire.
The laptop is about 4 years old, it is a toshiba satellite A25-S207. What is the simplest method for me to turn of my laptop in the car? I am sick of getting out and pressing the button in my trunk every day. Please dont just tell me to . I just need some help, (BTW im only 16).
black06stang is offline   Reply With Quote
Sponsored Links
Old 10-15-2006, 12:30 PM   #2
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
that mechanism HAS to connect to a switch that may be part of the mechanism, the computer has no way of knowing anything about mechanism's, all it can see is continuity between two points,those two points will be a ground reference & another that sees a ground pulse as an on signal request... you have to find these two points... any pictures??
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Old 10-15-2006, 02:17 PM   #3
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's CarPC Specs
Wiredwrx's Avatar
My Photos: (0)
Like TC said. That mechanism is connected to wires. At some point, the computer, an electrical device, needs to know that the button was pushed. THat is the point which you have to solder to. Just like, your car, when you put the key in and turn the it, that is mechanical, but the car knows this is donw because WIRES CONNECT power.
Pictures would be helpful, but they are probably no different then any other laptop.
Of course, if you are unwilling to use WOL, WOR, etc.., and your laoptop is "mechanical" as you state, then you can't use the laptop. Get something else.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 10-15-2006, 02:26 PM   #4
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Quote:
I don't want to mess with this..
I don't have that..
I can't do something else..
Don't tell me to search..
I just need help..
I recommend a long pole....but not to push the on/off button with!!! ;-)
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 10-15-2006, 03:11 PM   #5
turbocad6's Avatar
My Photos: (71)
if you really can't mess with the switch (wimp), a cable like a gastank release could be rigged, (bicycle cables) or a small electrical solinoid could be rigged even, but cleanest is to just go to the board...
Old 10-15-2006, 05:43 PM   #6
1bad2v's Avatar
Vehicle: 2003 Ford Mustang GT
My Photos: (0)
take you laptop apart and just solder the damn wires on the frikin switch and wire to your car how you see fit. No need for mechanical this or that.
1bad2v is offline   Reply With Quote
Old 10-15-2006, 06:00 PM   #7
McFreak's Avatar
Vehicle: 2003/G35/Coupe 6MT, Laser Red
My Photos: (0)
Bottom Docking Station
I found the pin that presses the power button on the bottom docking station port. I doubt it is the same but it was just one pin and then a ground to the case to turn it on and off... I have a picture if it would help. Though mine is an IBM laptop.
CarPC v2: Infiniti G35 Coupe 6MT, DW Housing, IBM R40, GPS, XM, StreetDeck
McFreak is offline   Reply With Quote
Old 10-16-2006, 03:05 PM   #8
My Photos: (0)
got a question do the length of the cables matter... like will it lose signal after so far?
darkdrake is offline   Reply With Quote
Old 10-16-2006, 03:08 PM   #9
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
My Photos: (0)
Which cables? And yes, it does and it will.
Michael
Old 10-16-2006, 04:06 PM   #10
Vehicle: 2001 Toyota Corolla
My Photos: (0)
Yup, think of Ohm's law, V=IR
The longer the cable, the more resistance. (R)
Parts: [||||||||||]
Build: [||||||||||]
2001 Toyota Corolla CE 5spd.
Laptop:
Pentium 4-M 1.8 Ghz
512mb RAM
40GB
SUPER 7" VGA w/ TC
crazyhorse is offline   Reply With Quote
Sponsored Links
Old 10-16-2006, 04:21 PM   #11
gutterslide's Avatar
My Photos: (0)
i just did this on a Toshiba A15-S1271. the laptops look nearly identical, the power button is in the same location, the motherboards are different, but it should be the same basic modification.
here is your motherboard, and your button location.
here is my modification. you can just use a multimeter to check for which solder points have continuity during button press, and then solder the extension wires to those points, and attach a momentary switch, startup/shutdown controller, or whatever. i installed a 1/8" audio jack (RadioShack #274-274) into an empty space for optional S-Video out, but you can make it as simple or as complicated as you want.
and, here is a great site with step-by-step tutorials for disassembling Toshibal Satellites. http://www.irisvista.com/tech/
gutterslide is offline   Reply With Quote
Old 10-16-2006, 08:20 PM   #12
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Beautiful. Nice mod.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 10-16-2006, 08:23 PM   #13
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
My Photos: (0)
Well done.
Michael
Old 10-16-2006, 08:30 PM   #14
Vehicle: 2004 Hyundai Tiburon GT
My Photos: (0)
My IBM Thinkpad X24 laptops power button is nearly impossible to get to. Few other threads on this board with people having similar problems. To get around this, I took out the battery and the laptop powers on whenever there is a power signal through the AC cable (ie when the car starts). However, you do have to manually shut down through your frontend/windows before you get out of the car, or else you run the risk of corrupted files.
vipervin is offline   Reply With Quote
Old 10-16-2006, 08:55 PM   #15
My Photos: (0)
Thanks for that great website for laptop tearing apart!
Sponsored Links
vB code is On
Trackbacks are Off
Remote laptop startup ambush Laptops, Tablets, UPMCs, etc. 46 06-06-2007 09:55 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Buying a laptop Rocky388 Laptops, Tablets, UPMCs, etc. 5 07-13-2006 01:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
