The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 10-24-2006, 10:25 PM   #16
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (64)
it's scarry the first time, but it works fine....use a tiny wire like a 22 ga, cut a tiny bit from the insulation, 1/16th maybe, as soon as you heat the tip, it'll pull the insulation back anther 1/16th or so as you tin the wire, tin it to the insulation.... it should look almost like a pin when your done,then just cut it shorter, you only need a tiny tip.. if it winds up a blob you used too much...
then you line the pin tip up with the point of the switch.... it looks scary, but the heat will only pull the solder togeather..., that's why you only wanrt the iron tip on the wire pin end, so you can't heat anything else enough for it to stick to anything but the tiny solder point....... the molten solder on the wire tip will heat the solder point enough for them to flow togeather...if it doesn't work or pulls off easily, try again but just a bit longer... eventually you'll get it
this is why you don't want to use flux... flux will distribute the heat, & will increase the chance of flowing solder to the case of the switch
don't expect to be able to lift the laptop with this joint, but it should be solid enough that playing it back & forth slightly should't make it come off, it's then a good idea to secure them somehow.... some use hotglue, but I use tiny wires from the switch & route them tucked till I can find a place to strap them too, tiny wire tie, whatever..., you can then increase the wire size if you want, especially if it's a longer run....
when you touch your two wires togeather & the laptop starts, sit back & grin
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Sponsored Links
Old 10-24-2006, 10:43 PM   #17
Sidewalksalvage's CarPC Specs
Sidewalksalvage's Avatar
Vehicle: 87 Toyota Camry
My Photos: (0)
Yeah..... much better advice than i could ever give!
And yeah that makes sense about the flux.......
Im usually working with bigger things......
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 10-25-2006, 09:19 PM   #18
My Photos: (0)
Thanks for the great advice! I think I am going to attempt it again tomorow!
black06stang is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
help with micro switch blackcar Hardware Development 9 05-21-2006 11:50 AM
New product - PC Power switch with wired remote hd54321 General Hardware Discussion 5 03-08-2006 10:48 PM
Need help with X31 port replicator power switch viguera General Hardware Discussion 1 06-22-2005 11:12 AM
Help needed on switch install for Inverter eazyrog Power Supplies 9 07-24-2004 06:42 AM
Savage Switch Botton Group Buy via UK's Iconstyling.com.... TheBigDog General Hardware Discussion 3 07-21-2004 10:51 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
