The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Search this Thread Display Modes
Old 11-23-2006, 10:48 AM   #1
miwise's Avatar
My Photos: (0)
Can I plug an AMD XP 2000+ into a laptop?
Will it damage anything if I try to plug my amd xp 2000+cpu (non-mobile) into my laptop motherboard with a duron 1100 mobile cpu? Its alright if it don't work, but will it damage anything if I test it? They are both Socket A CPUs. Thanks!
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Sponsored Links
Old 11-23-2006, 10:56 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Possibly.
It's likely taht it will work, although there will be two possibl issues:
1 - Heat dissipation. Teh AthlonXP will generate far more heat than the mobile Duron, and you're going to have to pull it out of the laptop casing somehow.
2 - The laptop may not be able to identify the AthlonXP properly, meaning you'll have to set FSB & multiplier settings manually, either in the BIOS, through jumpers or using the pin mod.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-23-2006, 05:39 PM   #3
miwise's Avatar
My Photos: (0)
Well, I'm going to look into it. The main reason I want to try it is not to install into my car. I wanted to test the motherboard with a faster processor. If it works, I'll probably get a mobile version.
Progress:
Old 11-24-2006, 05:08 PM   #4
miwise's Avatar
My Photos: (0)
OK, I tried the athlon xp 2000+ in my computer and it registered as an amd athlon 1200 mobile, but it crashed windows xp. . .blue screen (maybe overheated?). The fan kicked into super turbo mode as the 2000 generated a lot more heat. I guess this means it will not handle any more than 1200 megahertz (obviously a limitation of the board), so here's my question: If I buy lets say a mobile amd athlon xp 2000+ cpu, do you think it will be stable under windows xp? Will it run cooler than the stock 1100 mhz cpu as the new one will in essence be running underclocked to 1200 mhz? Thanks! BTW, I think my old 1100 duron bit the dust. I don't know what happened, but the computer just turned off while I was on my way home. I'm thinking it overheated, but I don't know. It won't even boot with the 1100 in the socket. I had a 1000 duron mobile laying around so I plugged it in and it boots perfectly to that. The freedom skin for roadrunner even runs under less cpu load. I guess the old cpu was just bad?
Progress:
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Can't install xp on my laptop HD camiloteram Operating System Optimization 2 07-12-2006 02:34 PM
WTB: Socket A CPU XP 2000 and higher CJ8501 Classified Archive 4 01-18-2006 12:23 AM
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 03:37 PM
power options missing on xp laptop hotponyshoes Software & Software Development 2 12-13-2004 08:01 AM
massive noise when i plug my laptop in robr Car Audio 20 06-01-2004 06:06 PM
Sponsored Links
Ad Management by RedTyger
