The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 11-28-2006, 06:15 PM   #16
miwise's Avatar
My Photos: (0)
Is the acrylic silver thermal paste just like the stuff they sale at radio shack? I have some heat sink compound from there. It's white. I used it sparingly on the cpu b/c I did know if it would be good to get extra on it. I put a dot in the middle of the cpu and installed the heat sink. It seems to run better when I use that 12 volt fan turned on constantly to keep the cpu cool. I'll check out zalman as I've never heard of that brand before, but it seems to work with a better fan. Thanks!
UPDATE: Ran the computer about 2 hours in the car today, and it worked beautifully. No crashes or anything. I used centrafuse to check the cpu temp a couple of times and it seems to be hovering around 55 degrees celcius now with the fan constantly circulating the air.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Sponsored Links
Old 11-28-2006, 11:19 PM   #17
Splash-X's Avatar
Vehicle: 2007 Mazda 3
My Photos: (0)
Thats good to hear.
I should correct myself, it should be called Arctic Silver and it is similar to heat compound you find at Radio shack but it does 10x better of a job. It will cost you around $11 for a tube of it but you'll get 2 or 3 uses out of one tube.
http://www.compusa.com/products/prod...ermal_Compound
or
or
http://www.newegg.com/Product/Produc...82E16835100007
or
http://www.zipzoomfly.com/jsp/Produc...uctCode=316503
You can buy it at your local computer store or order it online but after shipping it comes out to be the same price.
Splash-X is offline   Reply With Quote
Old 11-29-2006, 06:42 PM   #18
miwise's Avatar
My Photos: (0)
Thanks, I'll check into that!
Progress:
Old 10-18-2007, 07:06 PM   #19
Vehicle: 2008 Mitsubishi Colt Insport 1.3
My Photos: (0)
Quote: Originally Posted by Splash-X View Post
Thats good to hear.
or
or
or
NO!
2 or 3 uses ? you must be JOKING?!
You should only use a VERY small amount of Heatsink compound!
It has to be such a thin layer it's almost see-thru, it's so wrong to GLOB it all in, and tell other to do it.
A single tube of AS Compound lasts about 50 CPU's or more.
Apply a small drop and level it out with a credit card or the like, and you're set.
NOTHING transfers heat as direct contact does, AS compound is a bad conductor of heat, but better that air (air isolates)
// Per.
zapro is offline   Reply With Quote
Old 10-18-2007, 07:36 PM   #20
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
hey, he's right, the only reason you use compound is because the 2 surfaces can never mate perfectly on a microscopic level, the compound is just to fill microscopic voids & allows more heat transfer than the voids, if both surfaces mated perfectly then no compound would even be necissary...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Sponsored Links
Old 10-25-2007, 01:11 PM   #21
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
Just to thow in my $.02, it also helps to use some wet-dry sandpaper (600 grit, I think), and a few drops of water and dish soap to lap the heat sink to a polished surface before mating to the CPU with a very thin layer of Arctic Silver. 30 minutes of sanding will make for a well polished surface. If you can, do it with the sandpaper laid out on a flat glass surface, rough side up, and move the heat sink in circles on top of the paper while applying even pressure. You can pull those temps into the 40's with air, if you're careful and take the time.
hithere is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
why does my laptop turn on? Efess Laptops, Tablets, UPMCs, etc. 19 07-02-2007 08:45 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Powerbook g4 12" + other laptop parts (mainly from a D800) sabre Classified Archive 12 07-24-2006 10:12 AM
Buying a laptop Rocky388 Laptops, Tablets, UPMCs, etc. 5 07-13-2006 01:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
