The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 12-16-2006, 06:45 PM   #1
hypnotiq's Avatar
My Photos: (0)
Trouble finding a barrel connector for laptop
Hey,
I have a dell 600 m and i took my laptop's power charger to radio shack but they said they didn't have anything big enough. I would rather not cut off the one on my charger, so is there any other way i can find one?
hypnotiq is offline   Reply With Quote
Sponsored Links
Old 12-17-2006, 01:33 PM   #2
hypnotiq's Avatar
My Photos: (0)
anyone?
Old 12-17-2006, 07:17 PM   #3
billmee's Avatar
Vehicle: 2002/VW/Jetta Wagon TDI
My Photos: (4)
Yeah I'm in the same boat. I haven't found any source.
I bought a docking station that came with a psu and will probably hardwire it, that is open it up and solder the connections permanently inside.
That'll leave me with a spare connector for the car.
You can get psus on ebay for relatively cheap.
billmee is offline   Reply With Quote
Old 12-17-2006, 07:45 PM   #4
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (30)
Depends on the dell, some use a proprietary connector with a 3rd data pin that communicates whether or not it's an official adapter
Think you are in the same boat as me. I know someone actually sells replacements, but you still need a "official" psu for it to charge or work with a dock.
http://forumz.tomshardware.com/ce/la...opict9519.html
shotgunefx is offline   Reply With Quote
Old 12-17-2006, 09:45 PM   #5
hypnotiq's Avatar
My Photos: (0)
So is there no other option than buying a dock and soldering on the psu? I really would rather not have solder anything or have to buy a dock for no reason.
What if i just cut off the end of my OEM dell charge, and then crimp it onto the power wire of my psu?
Old 12-17-2006, 11:34 PM   #6
shotgunefx's Avatar
My Photos: (30)
Could you clarify what you are trying to do? Are you trying to fix a dell ac adapter or are you trying to power it from something else like a Carnetix 1900?
If the answer is B, you are SOL from what I could find. That's why I'm running an inverter
Old 12-18-2006, 12:39 AM   #7
My Photos: (0)
Had the same problem with a Compaq Laptop. I couldnt find an exact match, but i did find something .05mm off
Best best is check out Mouser.com
Epia MII12000 | 512MB RAM | ATI TV Card | 60GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | WinALDL hookup | 10.4 Datalux LMV10R | Opus 150W PSU.
blazinlow is offline   Reply With Quote
Old 12-18-2006, 01:27 AM   #8
shotgunefx's Avatar
My Photos: (30)
Mouser is a pretty good suggestion.. but, if he is trying to power his laptop off of anything outside of an official dell adapter and he has a model which has the chip in it, it won't charge the battery and it won't power a dock. Also will throw a BIOS error.
Dell sucks.
Old 12-18-2006, 01:44 AM   #9
hypnotiq's Avatar
My Photos: (0)
Yes, i do have a carnetix p1900. Theres a manufactorer of generic ac adaptors for my laptop on ebay, i think that means that i won't have to deal with the bios oem plug issue correct?
http://cgi.ebay.com/AC-Power-Adapter...QQcmdZViewItem
Also, since i'm in a hurry (road trip to vegas on wednesday) can i just cut off the end of my oem charger and use that?
Old 12-18-2006, 05:12 AM   #10
shotgunefx's Avatar
My Photos: (30)
If you have the third pin, nothing works as far as replacements, not even the Lind ones. The laptop will power on, but it will not charge.
Sponsored Links
Old 12-18-2006, 12:41 PM   #11
hypnotiq's Avatar
My Photos: (0)
What if i use a the connector from my orginial power source that has a third pin, would it trick the laptop into thinking that i'm using the original charger?
Old 12-18-2006, 04:15 PM   #12
strohj's CarPC Specs
strohj's Avatar
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
My Photos: (0)
why not just buy a used power supply for cheap on ebay??
strohj is offline   Reply With Quote
Old 12-18-2006, 04:43 PM   #13
shotgunefx's Avatar
My Photos: (30)
It's not a simple voltage divider like some, it actually has a chip in it the supply that talks to the laptop. What they say to each other, no one knows (or at least not google when I first researched it)
First of all, you sure you have one of those supplies? I think you do, but not 100%.
Old 12-18-2006, 06:25 PM   #14
billmee's Avatar
My Photos: (4)
well now I feel like checking this thing out.
I wonder if the pc can be powered by a simple 19v psu with the battery removed ? maybe some of the necessary communtication is to the battery.
Old 12-18-2006, 06:32 PM   #15
hypnotiq's Avatar
My Photos: (0)
I was reading this post by bugbyte:
http://www.mp3car.com/vbulletin/show...28&postcount=6
and it describes my charger exactly. So i also believe that i do have one of those connectors.
My originial question has never been answered though, if i cut off the end of my OEM dell charger would that work without a doubt with my p1900 since it will have the chip in it?
Thanks for all the help guys, i'm sure theres a bunch of other people with teh same problem
Sponsored Links
vB code is On
Trackbacks are Off
Navilock gps trouble! damoru2 GPS 2 07-30-2007 02:39 PM
Pandora w/ Xenarc 700TSV and Barrel Connector froalskiner General Hardware Discussion 7 07-20-2006 02:39 AM
What size barrel plugs for Xenarc 730tsv and Audigy NX 2? Mears General Hardware Discussion 6 08-29-2005 05:26 PM
Create an OBD Trouble Code? god_of_cpu Engine Management, OBD-II, Engine Diagnostics, etc. 14 05-16-2005 10:59 PM
Need help finding a sub box ... shakes Car Audio 13 05-12-2005 12:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
