The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 01-20-2007, 04:22 PM   #16
My Photos: (0)
ok but is it possible to hook up a dc-dc converter...say from 19V to 14V to the cnx1900....or is it possible to connect an inverter to the cnx1900
racerboy0712 is offline   Reply With Quote
Sponsored Links
Old 01-20-2007, 04:26 PM   #17
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
Please take a look at this thread...
http://www.mp3car.com/vbulletin/show...75&postcount=3
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 01-20-2007, 04:28 PM   #18
My Photos: (0)
hm when will that be complete....and im curious..what does "program jumpers" does that mean ill have to buy something seperate?
Old 01-20-2007, 04:34 PM   #19
Ruffy's CarPC Specs
Ruffy's Avatar
Vehicle: 2000/Chrysler/300M
My Photos: (0)
its possible but wastefull. You're laptop should handle 12v just fine. Go find a car adapter for your laptop instead of getting the carnetix if it truly requires 14V. It'll be cheaper in the end. Car adapter $20-80.
Then if you do get the carnetix it would provide power for your screen and your usb devices.
Don't use an inverter. They're innefficient. Noisy, And throw of EMF/EMI like crazy. Trust me I have a hardwired inveter in my car right now and its terrible. Going from DC(Car) to AC(Inverter) Back to DC is retarded.
But as I said your laptop should be able to handle 12 volts. Most laptops have a wide voltage range of 3 volts up or down. The power adapter for my laptop got lost. Got a replacement. The on I have is 2 volts under what the factory one was. Still works just fine and it's made specifically for my laptops model #.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 01-20-2007, 04:40 PM   #20
My Photos: (0)
sorry for the noob question but, is the only way to find the laptop's power output from online or a manual or is there something on teh computer that tells me.
also, if i plug in my gps reciever to my laptop, does that mean the Volts usage goes up?...and what if i use a docking station...does that have the same voltage need as the computer
Sponsored Links
Old 01-20-2007, 04:45 PM   #21
My Photos: (0)
http://h18000.www1.hp.com/products/q.../11455_na.html
that is where i am looking
also, http://www.notebooksupplies.com/compaq/evon1000v.html
is that what you mean by car adapter...would it be possible to hook this up the cnx1900 or where would i splice to give this power....the ACC where the ignition is? or the cig lighter
Old 01-20-2007, 06:12 PM   #22
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
yes a car adapter comes with a cigarette lighter 12v plug for easy use in a car. It's reccomend you cut that plug off and hardwire it into the car instead. It basically has a built in dc-dc conveter/regulator built in.
To have it turn on when the car is on takes some work. You wouldnt want to connect it directly to the battery or it would drain the battery when the car wasen't on.
Best bet it to setup a relay that's trigger when the car is on.
Old 01-20-2007, 06:32 PM   #23
My Photos: (0)
ok wow, so i just looked at the back of my laptop it says input voltage 18.5V and 4.9A......so im thinking thats the rigth one lol....and now im going to go with the p1900....thanks guys and sorry!
Sponsored Links
vB code is On
Trackbacks are Off
Carnetix Power to Laptop Wiring? AznArkitekt Laptops, Tablets, UPMCs, etc. 6 02-05-2007 06:53 AM
carnetix and laptop griz145389 Power Supplies 11 11-06-2006 10:51 AM
Carnetix powering laptop poxin Power Supplies 1 10-20-2006 07:13 AM
What could cause this problem? (laptop related) Rocky388 Laptops, Tablets, UPMCs, etc. 5 09-17-2006 03:17 PM
question regarding use of a Carnetix P1900 ichiban Power Supplies 4 07-01-2006 08:42 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
