Notices
Old 04-01-2007, 11:01 AM   #1
what is the part called that holds the ribbon to the buttonboard?
that brown 'tab' that is infamous for breaking when overly excited idiots like myself try to get their display unmounted? i simply want to know what that tab is called so i can research where to find a replacement. mine is only half broken so naturally the button-board on my eby-701 works half the time, if i apply excessive pressure to the housing causing stress on the joined surfaces.
a sloppy picture journal of the carPC progress
http://www.flickr.com/photos/dj3stripes (note the phases on the right to see progress)
dj3stripes is offline   Reply With Quote
Old 04-01-2007, 04:25 PM   #2
must be 30 people who've read so far who also don't know what it's called.
Old 04-01-2007, 06:43 PM   #3
Jahntassa's Avatar
I'd guess retainer.. but I don't know what it's technically called. I've never tried searching for one, unfortunately..
Jahntassa is offline   Reply With Quote
Old 04-01-2007, 07:41 PM   #4
it's probably called a flex cable connector. Checkout a site like mouser or digikey.com Your best bet is if you could determine the brand of the connector-sometimes there are symbols or initials on the connectors themselves.
ak47clown is offline   Reply With Quote
Old 04-02-2007, 12:02 AM   #5
cool. i appreciate all the info. has anybody else had to replace this part before? that's my main/only gripe about the eby-701 is the shortness of the ribbon cable going to the button/ir board. it seems that the 619/629 is much longer. the red light comes on all the time the way it is now but w/out applying pressure to the fram the buttons have no response. when they do respond all the blue lights come on and the monitor works fine, i can't use the buttons but i dont need to adjust the settings. i wonder if i were to locate my remote if i could just use that to power the thing on?
Old 04-02-2007, 12:09 AM   #6
you mean like this?
ZIF connector.
Epia MII12000 | 512MB RAM | ATI TV Card | 60GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | WinALDL hookup | 10.4 Datalux LMV10R | Opus 150W PSU.
blazinlow is offline   Reply With Quote
Old 04-02-2007, 12:17 AM   #7
YES! zero insertion force? like the old school cpu sockets? other than possibly having a number on it (which i don't believe it does) how do i know which one i need to order? i emailed lilliput but i doubt I'll get a reply.
Old 04-02-2007, 01:20 AM   #8
If it has the retaining lock its a ZIF (Zero Insertion Force)
There is also a LIF connector (Low Insertion force) but I do not believe they have a locking mechanism. You have to actually push the ribbon in these types of plug. ZIF's just slide in easy.
Id guess you need to know the number of pins, the width of the ribbon, and the length of the contact area. Not sure how they are replaced. Check out www.mouser.com
Old 04-02-2007, 01:24 AM   #9
excellent very helpful information, thanks a million, one more question pops in my head. i assume you count the number of lines in the ribbon to determine the number of pins?
Old 04-02-2007, 01:29 AM   #10
Fusion Brain Creator
2k1Toaster's Avatar
Yes it is a ZIF socket, and to count the number of pins, yes just count either the lines in the ribbon or the pins that are soldered to the board on the socket itself.
Old 04-02-2007, 01:32 AM   #11
Banned
Motorcity's Avatar
You will also find these at Mouser or Digi-Key as FFC connectors. Flat Foil.
They come in lock tab and LIF.
Motorcity is offline   Reply With Quote
Old 04-02-2007, 01:38 AM   #12
again thanks for the help should this be stickied or is it a bit rare for people to have to replace this type of part? perhaps a glossary of terms to help non-circuit savvy folks like myself identify what it is they're trying to repair?
Old 04-02-2007, 09:03 AM   #13
Banned
Motorcity's Avatar
Problem is, those connectors are SMT, and are not the easiest to re-work.
A hot air solder station is needed to remove and repalce them. It is a real pita.
Old 04-02-2007, 09:49 AM   #14
that sucks, i thought i could simply pop in the plastic tab and wallah......... boo.
Old 04-02-2007, 10:08 AM   #15
Banned
Motorcity's Avatar
you and a lot of other people.........
I broke the Xenarc plastic tab (that holds ribbon cable) justintime LCD/Display 13 09-22-2005 01:06 AM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 04:29 PM
Lilliput 8" ribbon cables? therussman2002 General Hardware Discussion 4 12-24-2004 10:17 AM
lilliput digikey replacement ribbon part # netboy LCD/Display 1 10-26-2004 11:41 PM
What is this part called???? welthqa LCD/Display 6 11-17-2003 03:29 AM
