The MP3car.com Store
Thread Tools Display Modes
Old 04-02-2007, 07:11 AM   #1
PontiacGA's CarPC Specs
PontiacGA's Avatar
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
My Photos: (0)
Touchscreen 'ribbon' cable...
Is there any way to fix a broken 'ribbon' cable (sorry,dont know the tech term. ) to the touchscreen. Somehow during taking it apart and putting it back together, the one 'wire' was ripped, so now windows doesnt recognize the touchscreen.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Sponsored Links
Old 04-02-2007, 08:01 AM   #2
Banned
Motorcity's Avatar
My Photos: (0)
If the contact points on the touch panel are easy to get to , you could solder on a new cable.
The flex ribbon itself is not repairable.
Motorcity is offline   Reply With Quote
Old 04-02-2007, 08:47 AM   #3
PontiacGA's Avatar
My Photos: (0)
No. Cant get to the contact points. This one here looks exactly like mine. Will it work or what? I have the VM7200 from short-circuit. Both are 4 wire ones and the ribbon is in the same spot.
http://www.digitalww.com/store/prodd...sp?prod=TS7PMH
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 04-02-2007, 09:06 AM   #4
Banned
Motorcity's Avatar
My Photos: (0)
If your connector looks like this, then I have a new panel in stock.
55.00 shipped in US.
Old 04-02-2007, 06:59 PM   #5
PontiacGA's Avatar
My Photos: (0)
Thanks, but mine dont have the plastic connector. It looks exactly like this one.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 04-02-2007, 07:24 PM   #6
Banned
Motorcity's Avatar
My Photos: (0)
ok, I see now. Yours has the ffc connection.
Old 04-03-2007, 09:13 AM   #7
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
You can try repairing it using window heater/defroster wire repair. Basically, it's a conductive paint and can be found at autopart store. I am not sure if it work, but trying is the key .
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-03-2007, 07:25 PM   #8
PontiacGA's Avatar
My Photos: (0)
Ah, good point. I'll try that. Thanks. Then if that doesnt work, I guess a spend $50 on a new one.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Old 04-04-2007, 05:18 AM   #9
Phreak Show's Avatar
Vehicle: Renault Clio II
My Photos: (0)
If that doesn't work, try putting a sponge under the cable, scratch a bit on the surface to remove the isolation and then solder directly to the wire. Sponge should be wet, of course
Phreak Show is offline   Reply With Quote
Old 04-04-2007, 08:11 AM   #10
PontiacGA's Avatar
My Photos: (0)
The defroster trick worked!! Just scrapped the insolation off, applied the paint and now the touchscreen works! Thanks Matrix.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Sponsored Links
Old 04-04-2007, 08:26 AM   #11
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Glad it worked.
Sponsored Links
vB code is On
Trackbacks are Off
Ribbon cable wont stay in KennyKen LCD/Display 0 01-13-2007 07:37 PM
lilliput ribbon cable EsKALad General Hardware Discussion 4 07-25-2005 10:51 PM
Help connecting touchscreen controller - which way to insert ribbon? (Pics) kingvitamin LCD/Display 5 05-07-2005 02:25 PM
Changing the Lilliput Din connector to a ribbon cable... The Grinch LCD/Display 10 08-12-2004 04:45 PM
To extend my 5 wire touchscreen cable or not? e_fractal General Hardware Discussion 1 11-07-2003 04:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
