Old 04-03-2007, 10:23 AM   #1
MySQL Error
MatrixPC's Avatar
SUPER/AVATAR Controller pinout needed
Hi guys,
I bought a 2nd hand Super VGA LCD TS that has some of the connector cut due to the stupid placement of the main connector. While doing the fab, I found that it is impossible to place the controller without any interfere with the existing components. So I have few option to work with.
- Extended the high voltage wires (CCFL wires).
- Chop the CCFL inverter and extended the input wires.
- Desolder the 26 pin connectors and solder new different connectors.
The first 2 options give me an option to have the controller lying horizontally in the setup. I am kindof don't want to chop the inverter unless it is broken like greenman100 did. Cutting CCFL is okay cuz i did it before with the PSOne, but because of the fire risk (Although I had no problem for 2+ years with the PSOne using regular wire) I want to do it the correct way. Either these 2 options I take, I still endup with a stupid connector. So I take the 3rd option, desolder the connector and make new one. So here we go.
I already found all correspondence pins that going to the 9pin mini DIN an
The controller look exactly like this. Thanks to eric couratier.
I called this the "front" side which is all the components attached to. The "back" side is where the solder joint is as in this pic. Thanks to greenman100
Now if you look at the back of the controller (greenman100 picture) I label the pin like this.
Code:
Top of the controller. I called it CN. 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 Bottom of the controller where you plug the harness in. Male 9pins mini DIN from the harness (see attach image). ==== 7 8 9 3 4 5 6 1 2
Now let match the pin together. Those label as GROUND are all well GROUND. I just don't know which ground to which like VGA ground, audio ground (just assumpt that if it next to audio, it's audio ground.)
Code:
Controller CN 9 DIN Pin Function. 01 GROUND 02 5 TS GROUND 03 6 TS Data+ 04 GROUND 05 Composite Video Signal (Inner Yellow RCA) 06 Composite Video Ground (Outer Yellow RCA) 07 9 VGA 01 RED 08 AUDIO + (Could be Left channel) 09 3 TS +5 VDC 10 4 TS Data - 11 SVIDEO (Red: Either Y or C) 12 GROUND 13 1 VGA 03 BLUE 14 GROUND 15 AUDIO + (Could be Right channel) 16 ???? (No Connection ???) 17 GROUND 18 SVIDEO (Grey: Either Y or C) 19 SLEEVE VGA GROUND 20 2 VGA 02 GREEN 21 +12 VDC 22 +12 VDC 23 GROUND 24 GROUND 25 8 VGA 14 VSync 26 7 VGA 13 HSync
Now can you guys fill out the ???? in the above pin?
Or can anyone take a closeup picture of the main connector and the related connectors (Video, SVid, Audio ... ). My main connectors still have something left that I can use as reference to trace the pin.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-04-2007, 09:19 AM   #2
MySQL Error
MatrixPC's Avatar
You guys suck. With that many of you guys buying this same/similar screen and no one can take a good pic for me?
Anyway, it's time to kiss good buy that stupid connector.
Tools responsible for taking that connector out.
After 2 hrs and burn my 2 fingers ( bubble), the sucker is OUT
A closer look
See that CAT5 Cable? Yup that is going to be the new cable with 9pin special mini DIN pre-solder.
After taking that connector out, I am sooooo freaking
Old 04-05-2007, 09:18 AM   #3
MySQL Error
MatrixPC's Avatar
Some more pic of the process.
Old 05-06-2008, 05:56 PM   #4
Quote: Originally Posted by MatrixPC View Post
Hi guys,
Code:
Code:
You rock, I owe you big time for this post. I also removed that stupid centronics 26pin connector and soldered directly to controller. I feel like ***** now for not contributing more to this forum and its members. My thanks to you.
miro2u is offline   Reply With Quote
FS: DiCON LCD1280EI LCD controller + Samsung 14.1" TFT 41_ Classified Archive 6 08-23-2006 04:59 PM
Xbox controller... thekage Input Devices 23 12-02-2004 12:02 AM
WTB: 10.4" touch screen overlay & controller Cordell Classified Archive 10 08-06-2003 07:15 PM
Pinout needed for serial ports? Sleeka General Hardware Discussion 4 11-09-2002 03:17 PM
Trade 8.4" LCD with controller for Alan controller Sleeka Classified Archive 3 05-14-2002 11:09 PM
