09-01-2007, 10:25 PM
#136
i got it. I used the reg settings from post #12 on this thread http://www.mp3car.com/vbulletin/lcd-...m-drivers.html
All I did was modify the long string as vlad described above and now the display settings report 800x480 and the monitor confirms that it's getting that input as well.
Thanks guys!
09-02-2007, 02:42 AM
#137
Location: Singapore - Smallest country in Southeast Asia
Vehicle: 2005 Fiat Doblo
Quote: Originally Posted by Giuliano
Folks,
Here's a package that was built to cover 800x480 with Xenarc timings on the Analog VGA port, for all of these Intel chipsets:
852GM
852GME
845GV
855GME
915GM
915GV
945G
945GM
Here is the package:
http://moschini.org/ALL-VGA-800x480-Xenarc.zip (925k)
Hi,
I am using 855GME and 700IDT, i would like it to display at 800x480.
I have tried your custom driver, registry trick and powerstripe...but i am still stuck at 800x600.
BTW, there is a new IEGD 7 on intel website, possible to customise based on that?
Pls advise.
09-02-2007, 05:25 PM
#138
Vehicle: Honda Civic EX AT 95
Test hbernation. In the end I went back to 800x480 with regular intel drivers, because hibernation stopped working (and that is important to me).
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [ ||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
09-02-2007, 08:18 PM
#139
how do u manage to get 800x480 with regular intel driver? which method u used?
thanks
09-03-2007, 02:32 PM
#140
thanks
No, with regular drivers I had to stay with 800x600.
\/ |_ /\ [)
1995 Civic Sedan EX
09-03-2007, 09:27 PM
#141
yeah I have the same issue. but the correct resolution looks so much better than the alternatives that it will be hard to go back
09-04-2007, 06:38 AM
#142
I feel the same, but hibernation is very important to me. CarPC will hibernate when ignition is off, and will resume when ignition is on. I tought of not using hibernation, and then I installed TinyXP to reduce the boot time, but still is much longer than just resume from hibernation, not mentioning that hibernation will return to where you were in the apps, etc...
I am currently using a regular PC MoBo, and I am considering buying a mini-itx board, and I hope to get 800x480 from it with hibernation.
\/ |_ /\ [)
1995 Civic Sedan EX
09-04-2007, 09:26 AM
#143
Vehicle: 1937 Ford Cabriolet
Make sure you do your research on the Mini-ITX systems
Because the Via systems CANNOT do 800x480 unless your running Linux and it has been this way for YEARS.
I am getting 800x480 out of my 945GM chipset using the drivers in this thread on Vista just fine (no Aero mind you, but I am willing to live without that for the moment).
09-04-2007, 10:57 AM
#144
Hi. OK but are you having problems with hybernation? Btw, in my case the chipset is Intel 815.
\/ |_ /\ [)
1995 Civic Sedan EX
09-05-2007, 04:17 PM
#145
I don't think the 815 is part of the same chipset family
This thread is about getting 800x480 out of the 945GM/GMA950 chipsets though.
I am using the 945GM chipset and the drivers from this thread work to give me 800x480 and I can hibernate on Vista just fine with them.
09-05-2007, 09:24 PM
#146
Do any of these drivers work with xp x64?
09-06-2007, 08:22 AM
#147
Nope
They are all 32 bit drivers and the install packages are not digitally signed (an x64 requirement).
09-06-2007, 11:58 AM
#148
i am using 855 chipset with Xenarc 700IDT
manage to get it display at 800x480 using version 5.1 with hacked registry and power stripe
however the width of the display is few pixel too wide, so part of the screen is "cropped" away.
tried to tweak the value but still cannot get it right.
any idea?
09-13-2007, 08:24 AM
#149
I am using an intel mac mini on windowsXP and a lilliput 7". How can i get the mac to display 800x480?
I've tried searching and I still couldn't get a solution. It's been hours since.
Pls help me out here ok.
10-03-2007, 02:08 PM
#150
1440x900
Could someone please help me write a custom driver for the 945G that supports 1440x900? Thanks in advance.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
