The MP3car.com Store
Thread Tools Display Modes
Old 04-17-2007, 12:48 PM   #16
My Photos: (0)
Giuliano, do you think this might get you what you need? Thanks again.
BadCyborg is offline   Reply With Quote
Sponsored Links
Old 04-17-2007, 04:15 PM   #17
My Photos: (14)
BadCyborg:
Yeah, the Phoenix EDID editor is useful sometimes.
Run it on your machine, and then click the Extract EDID Registry button:
The timing parameters we want should be shown here..
Giuliano is offline   Reply With Quote
Old 04-17-2007, 05:19 PM   #18
My Photos: (14)
Quote: Originally Posted by rigg419 View Post
Sorry, a bit off topic and unrelated to car pc's.
First, I gotta give props to Giuliano. Whenever you put out something like this which is a total solution to a common problem, you're going to get morons like me asking stupid questions. that said....
I have an old (2005 is old in computer terms lol) alienware sentia with an intel chip. I use it as an HTPC and have it plugged into my 720p TV (Samsung HL-S5686W DLP if that helps), but the sentia won't output 1280 x 720, only 1024 x 768 (which looks odd) and 1280 x 800 (which the tv won't display).
The version of powerstrip I own (bought it a while back for my last carpc) is laughed at by the intel driver, and so I was wondering if there's a way I can make/find a driver for my chipset -Intel 82852/82855 (855GME)- which will allow the sentia to output 1280 x720 @ 32bit color and 60hz?
Thanks, and sorry for the unrelated/stupid question, but it's been a thorn in my side since I got the tv in february.
rigg419,
Here's your driver package for 1280x720 (progressive) 32-bit @ 60hz:
http://moschini.org/855GME-1280x720p.zip
File size is 925k as before.
Extract, go into the Utilities folder, and run Setup.
This should spit out 1280x720 non-interlaced on the analog VGA port as the only adapter.
If you have DVI instead, let me know..
Old 04-17-2007, 05:28 PM   #19
My Photos: (14)
This is also good info:
http://isnwiki.jot.com/WikiHome/Articles/111111431
There's a section in the .inf files for the Intel Video drivers for the 915, 945, and 965 chipsets that allows you to use custom EDID timings right from the INF.
For example, this is one that I made for 800 x 480 (Xenarc timing) using the Vista drivers:
Code:
[NonEDIDMode_AddSwSettings] HKR,, TotalDTDCount, %REG_DWORD%, 1 ; This shows number of DTDs to be used. ; 0-->Disable the feature. ;Following keys have 20 bytes (18 byte DTD + 2 Byte flags). HKR,, DTD_1,%REG_BINARY%, 96, 96, 20, e8, 30, e0, e8, 10, 28, 50, 00, 00, 19, 10, 00, 00, 00, 00, 00, 00 ;800 x 480 HKR,, DTD_2,%REG_BINARY%, 01,1D,80,18,71,1C,16,20,58,2C,1A,00,00,00,00,00,00,86,37,01 ;1920x1080@60...Interlaced HKR,, DTD_3, %REG_BINARY%, 01,1D,80,D0,72,1C,16,20,10,2C,1A,80,00,00,00,00,00,86,37, 01 ;1920x1080@50...Interlaced HKR,, DTD_4,%REG_BINARY%, 01,1D,00,BC,52,D0,1E,20,B8,28,25,40,00,00,00,00,00,04,37, 01 ;1280x720@50....Non-interlaced HKR,, DTD_5, %REG_BINARY%, 01,1D,00,72,51,D0,1E,20,6E,28,25,00,00,00,00,00,00,06,37,01 ;1280x720@60....Non-interlaced HKR,, DTD_6,%REG_BINARY%, 00, 00, 00 ,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00 ;Fifth DTD
That 5th line is actually where I pulled the 1280x720 @ 60 hz timings for rigg419.. I had to decode it for the individual parameters to plug into a DTD for the IEGD driver tool.
It's a serious mind twister to decode, though.
Here's the key:
Code:
These are VESA standard timings information in EDID. The decoder ring for the 18 bytes is as follows: 1. Low Byte of DClk in 10 KHz 2. High Byte of DClk in 10 KHz 3. Horizontal Active in pixels, LSB 4. Horizontal Blanking in pixels, LSB 5 Bit 7-4: Upper 4 bits of Hor. Active 5 Bit 3-0: Upper 4 bits of Hor. Blanking 6. Vertical Active in lines, LSB 7. Vertical Blanking in lines, LSB 8 Bit 7-4: Upper 4 bits of Vert. Active 8 Bit 3-0: Upper 4 bits of Vert. Blanking 9. HSync Offset from Hor. Blanking in pix., LSB 10. HSync Pulse Width in pixels, LSB 11 Bit 7-4: Lower 4 bits of VSync Offset 11 Bit 3-0: Lower 4 bits of VSync Pulse Width 12 Bit 7-6: Upper 2 bits of HSync Offset 12 Bit 5-4: Upper 2 bits of HSync Pulse Width 12 Bit 3-2: Upper 2 bits of VSync Offset 12 Bit 1-0: Upper 2 bits of VSync Pulse Width 13. Horizontal Image Size, LSB 14. Vertical Image Size, LSB 15 Bit 7-4: Upper 4 bits of Hor. Image Size 15 Bit 3-0: Upper 4 bits of Vert. Image Size 16. Horizontal Border in pixels 17. Vertical Border in lines 18. Flags: Bit 7: 0 = Non-interlaced, 1 = Interlaced Bit 6-5: 00 = Reserved Bit 4-3: 11 = Digital Separate Bit 2: Vertical Polarity (0 = Negative, 1 = Positive) Bit 1: Horizontal Polarity (0 = Negative, 1 = Positive) Bit 0: 0 = Reserved" 19. Leave as 37 20. Leave as 21
Old 04-17-2007, 06:17 PM   #20
rigg419's CarPC Specs
rigg419's Avatar
Vehicle: 2001 PreRunner TRD
My Photos: (0)
Quote: Originally Posted by Giuliano View Post
rigg419,
I do in fact use VGA, you must be a mind reader!
I can't wait to get home so I can try this. Do you have a paypal? I'd love to throw you a quid as a token of my thanks. Alternatively, I'm a decent graphic designer if you need something photoshopped
rigg419 is offline   Reply With Quote
Sponsored Links
Old 04-17-2007, 06:34 PM   #21
My Photos: (14)
Glad I could help..
Old 04-18-2007, 01:59 PM   #22
Felix509's CarPC Specs
Felix509's Avatar
Vehicle: 1999 Landcruiser
My Photos: (52)
Hey there Giuliano, i don't recon i could sweet talk you into a XP Pro driver for the Intel G965 using VGA and a 800x480 rez on a Xenarc 700tsv?
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Old 04-18-2007, 02:17 PM   #23
My Photos: (14)
Quote: Originally Posted by Felix509 View Post
Hey there Giuliano, i don't recon i could sweet talk you into a driver for the Intel G965 using VGA and a 800x480 rez for Xenarc 700tsv?
Here you go:
http://moschini.org/G963-G965-800x480-Xenarc.zip
Analog VGA only, 800x480 Xenarc timings on G963 or G965 chipsets.
Let me know how it works!
Thanks,
G
Old 04-18-2007, 03:16 PM   #24
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
Giuliano,
I'm getting the "not all components of the driver installed properly" error after I execute the executable. This is on a Dell Inspiron 6400 with Intel 945GM graphics chipset. I extract the file, then run the setup in the utilities folder, as specified....anything I may be missing?
hithere is offline   Reply With Quote
Old 04-18-2007, 03:17 PM   #25
My Photos: (14)
Folks,
Here's a package that was built to cover 800x480 with Xenarc timings on the Analog VGA port, for all of these Intel chipsets:
852GM
852GME
845GV
855GME
915GM
915GV
945G
945GM
Here is the package:
http://moschini.org/ALL-VGA-800x480-Xenarc.zip (925k)
NOTE:
The above package may not work on laptops, or systems with LVDS LCD panels attached. Analog VGA ONLY!
I will build a package for laptops / LVDS and Analog VGA combinations shortly.
I should also note that these configuration settings are not fixed in stone.
They can be changed any time, using the IEGDGUI utility in the Utilities folder.
Old 04-18-2007, 03:20 PM   #26
My Photos: (14)
Quote: Originally Posted by hithere View Post
Giuliano,
That's a laptop... the driver build package didn't account for the local LCD panel, which it needs to.
I'll build another package with the settings for a local LCD panel on the LVDS port.
http://moschini.org/945GM-LVDS-VGA-800x480-Xenarc.zip (925k)
This should set up the configuration with local LVDS LCD panel at its defaults, and the analog VGA port at 800x480 Xenarc timings.
The two displays are set up in Clone mode, so both displays will have the same image.
You can change this or adjust settings using the IEGDGUI utility mentioned above.
For best results, uninstall any previous driver packages from Add/Remove Control Panel first.
Old 04-18-2007, 03:44 PM   #27
My Photos: (0)
WOW that was fast. I'm so impressed by the level of generosity on these forums. I'll give the package a try shortly and get back to you on results.
And, once again, thank you.
Old 04-18-2007, 03:48 PM   #28
My Photos: (14)
Actually, it's quite easy..
The Xenarc timings were the most difficult part, and once I got that decoded into a Device Timing Description (DTD) file, I can re-use it for different builds.
For laptops, I'm defaulting to having both displays set in Clone mode, where they display the same content, but can have different resolutions.
These settings may not be optimal, but you can change it using the IEGDGUI utility or the Advanced button on the video control panel.
Old 04-18-2007, 03:56 PM   #29
My Photos: (14)
LVDS (Local LCD) and Analog VGA - Laptops
Here's a build for local LVDS LCD panels (Laptop LCD) and Analog VGA, with Xenarc 800x480 timings.
Chipsets:
855GME
915GM
945GM
Package:
http://moschini.org/ALL-LVDS-VGA-800x480-Xenarc.zip
All the other chipsets don't have LVDS ports on the chip - use this one instead for Analog VGA only:
Old 04-18-2007, 06:33 PM   #30
My Photos: (0)
Giuliano, please accept my apologies, but none of these seems to work. I'll try a few different things and get back to you. Sorry to be a PITA, I sure do appreciate your efforts,
Sponsored Links
vB code is On
Trackbacks are Off
FAQ REQUEST: CPU Ratings dontpntpool General Hardware Discussion 0 03-18-2007 03:39 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 02:56 PM
800x480 on Intel 845, some hope? sama LCD/Display 3 03-10-2006 02:25 AM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 01:16 PM
Possible (theoretical) BIOS fix for 800x480 on Intel Extreme Graphics? Giuliano LCD/Display 3 10-21-2004 11:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
