Quote: Originally Posted by
Giuliano
Hithere,
Do you know which one of these your laptop LCD panel is, on your Dell Inspiron 6400?
WXGA (1280 x 800)
WSXGA+ (1680 x 1050)
If I can find out what the panel is, I think I can build a DTD for the laptop LCD panel and use the IEGD package builder.
-G
wsxga...I'll do the moninfo and get it to you in an hour or so.
Edit: Here you go:
Monitor 1 creates this report:
EDID-0
ID SEC3250
SN n/a
This is the text I see for monitor 1:
Monitor
Windows description......... Plug and Play Monitor
Manufacturer................ Seiko-Epson
覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Plug and Play ID............ SEC3250
Serial number............... n/a
EDID data source............ Registry (stored)
覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Manufacture date............ 2006
EDID revision............... 1.3
Display type and signal..... Digital
Sync input support.......... n/a
Screen size................. 2550 x 2550 mm (~155")
Power management............ Standby, Suspend, Active off/sleep
Color characteristics
Display gamma............... 3.55
Red chromaticity............ Rx 0.625 - Ry 0.340
Green chromaticity.......... Gx 0.285 - Gy 0.605
Blue chromaticity........... Bx 0.148 - By 0.063
White point (default)....... Wx 0.281 - Wy 0.309
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 1680x1050 at 60Hz
Modeline................ "1680x1050" 119.230 1680 1728 1760 1840 1050 1052 1058 1080 -hsync -vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
800 x 600 at 60Hz - VESA
1024 x 768 at 60Hz - VESA
1680 x 1050 at 60Hz - Seiko-Epson
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C A3 50 32 00 00 00 00
10: 00 10 01 03 80 FF FF FF EA 00 00 A0 57 49 9B 26
20: 10 48 4F 21 08 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 93 2E 90 A0 60 1A 1E 40 30 20
40: 26 00 4B CF 10 00 00 19 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B7
Display adapter
Adapter description......... Mobile Intel(R) 945GM Express Chipset Family
Adapter device ID........... 0x27A28086
Display settings............ 1680x1050, 32bpp
Here is the text I see in the report for the second monitor (xenarc not hooked up, will do so if you request):
EDID-0
ID SEC3250
SN n/a
Here is the text I see in the window:
Monitor
Windows description......... Seiko-Epson Monitor
覧覧覧覧覧覧覧覧覧覧覧覧覧覧
EDID data source............ I2C bus (real-time)
覧覧覧覧覧覧覧覧覧覧覧覧覧覧
Screen size................. 330 x 210 mm (~16")
Power management............ n/a
Display gamma............... 2.20
Red chromaticity............ Rx 0.580 - Ry 0.340
Green chromaticity.......... Gx 0.310 - Gy 0.550
Blue chromaticity........... Bx 0.155 - By 0.155
White point (default)....... Wx 0.313 - Wy 0.329
n/a
Raw EDID base
10: 00 10 01 03 80 21 15 78 0A 87 F5 94 57 4F 8C 27
20: 27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
40: 26 00 4B CF 10 00 00 19 00 00 00 0F 00 00 00 00
50: 00 00 00 00 00 3C D2 02 64 00 00 00 00 FE 00 43
60: 46 32 36 34 02 31 35 34 50 32 0A 20 00 00 00 FE
70: 00 28 3F 48 54 7D A3 D3 FF 02 01 0A 20 20 00 55
Display adapter
Adapter description......... Auxiliary port
Adapter device ID........... 0x27A68086
Display settings............ n/a
