See, the whole .INF setup tweak is supposed to have been made FOR the G965 / X3000 chipset..
That's how Intel lets their OEMs add custom resolutions to the driver set.
I suspect that I have something major wrong with the 18-byte EDID string.
On the one hand, the EDID string kind of works by showing the 800 x 480 resolution in the list.
However, it's the wrong refresh - 601 Mhz instead of 61 Mhz.
This is something I won't really be able to test until I get a Xenarc to test it on, and I won't be able to do that for at least another two weeks.
I'm going to be out of town basically for the next 4 weeks, so I won't be able to work much further on this subject until around May 28th (Memorial Day).
I am resolved to make this work, so I'm not giving up. It just may take a little while..
Also, Nvidia cards can set custom resolutions.. the least expensive Nvidia card I could find is about $40, for a 6200 PCI-E version.
However, if you're going to spend $40 on a different video card, it's probably better just to spend the $30 on PowerStrip instead.
According to the release notes, they added support for Intel GMA graphics on 4/06/2007:
04/06/2007 - 3.74.584
- Added preliminary R6xx support
- Improved R5xx timing support
- Added Intel GMA custom resolution support
- Improved EDID write routines
Try the latest demo version and see if it does anything for you.
The Xenarc timings are here if you need them:
http://www.xenarc.com/faq.html#QA1
