The MP3car.com Store
Thread Tools Display Modes
Old 02-01-2008, 10:43 PM   #181
ptk
ptk's CarPC Specs
Vehicle: 2006/VW/GTi
My Photos: (0)
I did it from powerstrip. how do i translate the timing from powerstrip to DTD values? I too will prefer to use registry setting instead of powering up powerstrip all the time.
CarPC Ver 3 near completion.
ptk is offline   Reply With Quote
Sponsored Links
Old 02-02-2008, 09:01 AM   #182
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
It's a bit tricky to find and the procedure to find the values is listed earlier in this thread. You may also have to then convert decimal to hex (can't remember).
If you can't figure it out, let me know.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
galvitron is offline   Reply With Quote
Old 02-04-2008, 03:05 PM   #183
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
Hi fella.. just wondering if you think this is possible.
I have a minimac 1.66 with a 945 chipset / GMA950 graphics set. I have just bought a matrox dualhead2go digital box which I was hoping would split a 1600x600 resolution over my 2 800x600 screens (well there 800x480, but I want to use 800x600). Anyway installed them all but it says in the matrox manual to just select the streched screen res. BUT 1600 x 600 isnt there.
Do you think its possible to edit the drivers to make it output at this res ?
cheers buddy
CdRSKuLL
http://www.extremeoc.co.uk/
Building a new car soon - check it out !
www.BluePC.co.uk Bolton PC Repair - New Business venture.. I need to earn some money :-)
CdRsKuLL is offline   Reply With Quote
Old 02-04-2008, 03:42 PM   #184
galvitron's Avatar
My Photos: (0)
That Matrox stuff is a completely different beast than what is going on in this thread. Using the info in this thread you can get the GMA950 to output 800X480, but that is it.
You may want to contact Matrox for the other issue.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 80%
Old 02-04-2008, 05:45 PM   #185
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
Hi m8.. I know its different I wasnt asking that. I was simply asking if you think it would be possible to get it to output at 1600x600 as getting the gfx chip to output at a different res is what this thread is about.. which is why I posted it in this thread !
nevermind m8, I will look elsewhere
Old 02-04-2008, 05:48 PM   #186
galvitron's Avatar
My Photos: (0)
Well if you are trying to simply get the GMA950 to output at 1600 X 600 then you will need to calculate the DTD string for that.
As far as to how your Matrox thing would split that is beyond the scope of what is here and was at the root of your question.
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 80%
Old 03-12-2008, 08:14 PM   #187
kelmk's Avatar
Vehicle: 2002 BMW 330ci vert
My Photos: (100)
Anyone have the drivers from the start of the thread, specifically the laptop ones? The links are dead.
kelmk is offline   Reply With Quote
Old 04-17-2008, 08:37 AM   #188
My Photos: (0)
Bump
I need ALL-LVDS-VGA-800x480-Xenarc.zip
any1 care to "seed" them?? i need them to start my build
TJ
tjjensen23 is offline   Reply With Quote
Old 04-17-2008, 09:48 AM   #189
creaseguard's CarPC Specs
Vehicle: 2006 Corvette Z06
My Photos: (0)
I have a few of these but not the laptop one.
Send me an email to crease-guard AT sbcglobal DOT net and I'll forward what I got.
Jay
creaseguard is offline   Reply With Quote
Old 04-17-2008, 02:47 PM   #190
ajscomp372's CarPC Specs
ajscomp372's Avatar
Vehicle: 2001 Pontiac Grand Am SE
My Photos: (0)
I think I may have a solution that will not require you to reinstall drivers. Go to http://www.avsforum.com/avs-vb/showthread.php?t=947830 and read the method they have posted there. I tried this on my board (MSI Fuzzy GM965) to get a resolution of 800x480. What I did was use the DTD Calculator with the settings from the xenarc website, and inputted these settings into the DTD calculator. I then wrote these settings to the registry, and by playing around with both the intel app that sets the resolution, and the built-in "display properties" in windows, I was able to get 800x480. It can get a little complicated, and I only used this method because powerstrip didn't work. It's kind of a brute force way to do it, but it gets the job done.
ajscomp372 is offline   Reply With Quote
Sponsored Links
Old 04-18-2008, 03:17 AM   #191
My Photos: (0)
i tried to follow your post but i got hella lost . What i;m trying to do is ive got an old fujitsu s6120 with 82825/82855 gm/gme onboard and i need to get it to output 800x480. My screen is a cheapy off ebay and not a xenarc or anything. Whats the best course of action? The screen is going to arrive soon, and everything software and hardware wise but the screen is setup.
Hows the best way to get the display to output at 800x480???
Old 04-18-2008, 09:28 AM   #192
ajscomp372's Avatar
My Photos: (0)
The best thing to do is to try and use powerstrip first. If powerstrip doesn't work, then you'll have to try the driver reinstall method, or the method I posted. I know, it's very complicated, and it's very difficult to understand. It will help if you read the linked articles from the post I linked to. I said that I used xenarc timings, but these timings will really work with just about any screen (I'm actually testing it on an old gateway CRT). I just used the timings to get it to output an 800x480 image. The only thing that will probably be necessary to get it to work on another (non-xenarc) screen is adjusting the horizontal/vertical position of the image, which can be done on the screen itself using the OSD.
Old 04-19-2008, 01:25 AM   #193
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
Vehicle: 2005 Fiat Doblo
My Photos: (2)
i manage to hack the registry as DTD calculator dont work on 855 chipset
anyway, after few mths of trail and error, i still cannot get it right
still few pixels too wide...so the side got cut off
kwchan is offline   Reply With Quote
Old 06-01-2008, 03:40 AM   #194
AnimeCommander's CarPC Specs
AnimeCommander's Avatar
My Photos: (6)
I have a Mac Mini with the Intell 945GM with DVI and a Xenarc 700TSV. I had to manually install the drivers linked here:
http://cartft.com/support/drivers/Intel_800x480/
These let me pick more resolutions, including 800x480. However, 800x480 puts my screen in a 'letterbox' format and the Xenarc shows it as 800x600. If I put it to 720x480, things seem properly proportioned and the screen is filled, but the Xenarc shows detects it as 800x480. This is very workable for me. There is only one problem: since installing the driver, I cannot no longer go in to Safe Mode - it just restarts the PC. This isn't a big deal for me, but I wanted it known. Maybe there is a fix? And sorry for reviving an almost dead thread.
AnimeCommander is offline   Reply With Quote
Old 06-01-2008, 09:58 PM   #195
My Photos: (0)
Hello,
I have a Mobile Intel 945GM Express Chipset Family on a Toshiba laptop.
Can anyone provide the following drivers from the original posts, they don't seem to be avaliable any longer?
945GM-LVDS-VGA-800x480-Xenarc.zip
My understanding is I need the LVDS versions.
Or should I use powerstrip, due to possible hibernation/standby issues?
Any other options or recommendations?
Regards,
DEM_968.
DEM_968 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ REQUEST: CPU Ratings dontpntpool General Hardware Discussion 0 03-18-2007 03:39 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 02:56 PM
800x480 on Intel 845, some hope? sama LCD/Display 3 03-10-2006 02:25 AM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 01:16 PM
Possible (theoretical) BIOS fix for 800x480 on Intel Extreme Graphics? Giuliano LCD/Display 3 10-21-2004 11:09 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
