Hi Guys,
Been doing a bit of searching around, I want to solder the IR directly to the controller board, since I have got rid of the front button control board. I figure I'll take the 5v for the IR Vcc from the same place as specified in the coyote auto power on mod:
So the 5v and GND are sorted, the data pin for the IR, I believe I have traced to a pin on the side of the SyncMOS chip, hard to describe without knowing how the pins are numbered. Starting from the dot on the syncmos chip its the 8th pin to the left. 6 on the dot side, 2nd one down on the west side of the chip. I know that is odd way of explaining it. (it just so happens theres a set of resistors just above this pin which are connected to the pin, easiest place to solder data wire to..)
Really I'm just hoping theres someone with a lilli open that can confirm the data pin of the IR goes to this pin (trace from button board IR to syncmos chip). Assuming pin 1 on the button board connector is on the left in coyote's illustration, the pin on the IC should also be connected to pin 10 of that button board connector.
Hopefully that was too poorly explained, if anyone wants more detail please let me know. I'm keen to solder this up tonight, but don't want to wreck anything.
Thanks heaps in advance,
Tim.
