Hi all
I have a problem with this screen
(click) that hopefully you'll be able to advise on.
I bought the screen a while back, and have been busy fabricating the surround into the console in the car. I'm happy with that now, all primed and sprayed and ready to roll. So, last night I start to put all the components of the screen back together, as I had removed the touchscreen overlay, the screen itself, and all three PCB's from the housing.
I disconnected the speaker, as I won't be using it, and 'roughly' put everything back as it should be. Connected up the power, and found that the screen will only stay on for about one second.
I've connected my laptop to the VGA, and when I switch the output to 'external' the Windows desktop image appears on the 7" tft but only for about 1 second, before going off again. There also appears to be some strange lines across the screen
Because i've taken it all apart, I've voided the warranty, so I can't send it back.
I'm sure it can't be knackered, so can anyone possibly suggest what the problem might be? Do you think, because it's not all back together properly and I'm holding it upside down with PCB's dangling, that maybe something is shorting? Or there's an earth problem? Or maybe because I disconnected the speaker?
I'm gutted, mainly because of the expense, but also because it all needs to be working before May 19th!
Any help appreciated.
