Notices
Old 05-03-2007, 05:25 PM   #1
FM Interference
What are the worst culprits for generating FM interference in the world of CarPCs?
When the carPC is on, I get dreadful FM reception on the headunit.
If I disconnect the VGA cable at the PC, the reception is back to normal - even if the screen is still on. I therefore deduce it's EMI from the VGA signal that causing the problem, and not from the PC intself or from the screen backlight.
I have a Xenarc 700TSV, moulded into the dash just in front of the gear lever, and the head unit is about 12 inches above it.
I've tried to re-route the radio antenna lead away from the screen and place some copper shielding between the two, but it doesn't make much difference.
Is it possible for the VGA cable to be affecting the FM reception further back in the car? Both PC and antenna are at the back, and have cable running through the car - at one point they are very close together.
The VGA cable is a middle quality one - not the best, but not the cheapest. This weekend I will try to swap it with a better quality triple shielded one, and re-route the antenna and VGA cables to avoid each other.
Anything else I could try?
Ian
Vodkapete is offline   Reply With Quote
Old 05-04-2007, 10:00 PM   #2
VMS
VMS's Avatar
i got the same problem, anyone?
Vehicle Media Systems
Australia Car PCs www.vmscarpc.com.au
VMS is offline   Reply With Quote
Old 05-05-2007, 09:07 AM   #3
drop the HU :-)
mscappa is offline   Reply With Quote
Old 05-06-2007, 01:33 PM   #4
Tried to re-route the antenna cable today, and it made no difference - I also re-tried the disconnecting VGA cable - which also didn't help.
I don't know why it helped last time and not now, but I no longer think it's the screen to blame.
I've also disconnected the GPS mouse, bluetooth dongle and USB cables with no effect.
So my latest theory is that it's coming from the PC itself - but which component - power supply? hard disc? motherboard?
Any suggestions?
Ian
Old 05-07-2007, 02:23 PM   #5
307SW_NLD's Avatar
I have found the power supply of the LCD screen to be a source of interference. There is a little switching PSU in the "egg" of my Lilliput and I need it to place it as far apart as possible from any audio cables. Probably be better of using the PSU of my Carpc for the LCD.
My car: 2003 KIA Sorento 2.5 CRDI AUT
Hardware: EPIA SP13000, 60Gb 2.5"HDD, M1-ATX, Lilliput 7", RADIO SiLABS, K8055 BOARD
Software: Road Runner, FreeDrive, PowerDVD, WinXP SP1
See: Velleman K8055 Plugin for Road Runner
Progress: [XXXXXXXXXX] 50 % DONE
307SW_NLD is offline   Reply With Quote
Old 05-17-2007, 01:53 AM   #6
Monkee's Avatar
I have the same problem and the only things that are hooked up right now are the PC components in the trunk. What gives?
eBay / Heatware
Monkee is offline   Reply With Quote
Old 05-17-2007, 03:15 AM   #7
pleyraki's Avatar
I solved the problem by just removing an FM signal booster I had installed in the past! (I had almost forgotten I had put it in there long before my carpc!). Also check if you have an antenna with a booster in it. You may then have to replace the antenna with a plain one, or disconnect the power from it.
Hope this helps.
A. Plevrakis
Iraklion, Crete, Greece.
pleyraki is offline   Reply With Quote
Old 05-17-2007, 12:35 PM   #8
Hope this helps.
I'll try that - my car DOES have a booster antenna, so I'll disconnnect the power and see what happens!
Ian
FAQ: EMI / RF Interference aoLhaTer The FAQ Emporium 7 02-05-2008 12:44 PM
New FM USB module, maybe good for our carputers? skywise Road Runner 57 11-04-2007 08:12 PM
RF interference with FM reception Exposure LCD/Display 3 11-02-2007 06:24 AM
FM radio interference from Opus 150 cMags Power Supplies 3 05-05-2006 10:37 AM
I lose FM reception with GPS on ... aoLhaTer GPS 0 05-17-2005 01:19 PM
