Old 05-09-2007, 01:40 AM   #1
mashfique is an unknown quantity at this point
9pin mini din or VGA/USB extension.
Which is a better option? 9 pn mini din extension from your trunk to front of the car to connect the lilliput LCD or using two seperate extension cables, one USB and one VGA. Any information will be helpful.
mashfique is offline   Reply With Quote
Old 05-09-2007, 09:31 AM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
You have to make a call on this one yourself.
Normally, I would do like this.
- If I'll plug the TS and other devices to the hub up front, I will run a vga and usb.
- If there is no other usb to be used up front, run a mini din
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 05-09-2007, 06:18 PM   #3
Thanks. I think I will use a usb and vga cable, cause i will have a cd drive in my glove box.
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 10-26-2009 05:33 PM
9-pin mini din extension cable for lilliput ummagawd LCD/Display 2 03-21-2005 05:06 AM
Lilliput with extension cables (9-pin mini-din vs. VGA) BriCubz LCD/Display 3 09-03-2004 08:07 PM
WTB Lilliput Extension FoxRunner Classified Archive 14 07-24-2004 02:52 PM
9pin extension cable in uk ??? eazyrog LCD/Display 6 05-13-2004 03:11 PM
