the above method works as well, however I still find things to be too small.
Quote:
THe problem with changing the actual resolution that way is that everything becomes big.
So for instance S&T2006 wont display correctly on anything less than 800x600.
That's why I recommended using a software called rezchanger. It will customize your screen settings to the appropriate size for applications that do not work in 640x480.
