Old 05-18-2007, 08:59 AM   #1
zx16v is on a distinguished road
Lilliput 629 help ASAP!!
hi all
my lilliput 629 works fine untill i disconnect the vga for a second.
i didnt notice before i disconnect the vga cable the sides of it.
if someone have a picture or can tell me if the side with the blue plastic on it goes to the back of the screen(i can see the blue plastic) and the side that goes to the board is upside down,(i dont see the blue plastic on the cable) or shold i see the blue plastic on both of the screen and the board.
both way i try but have a white screen when i turn the screen ON.also i try with a new cable and the same result of white screen.
all connectors are OK and like new
hope someone can help ASAP.
thanks
zx16v is offline   Reply With Quote
Old 05-18-2007, 04:03 PM   #2
going to sell the 629,any GOOD offers pls PM.
http://www.mp3car.com/vbulletin/vbcl...p?do=ad&id=442
Old 05-18-2007, 04:29 PM   #3
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
have a search around the forums for "white screen of death" Check your ribbon cable that goes from the screen to the screen controller. This is a common result when the ribbon cable is not properly seated.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 05-18-2007, 04:32 PM   #4
i try to move the cable in evry angle,the cable looks ok,the connectors looks ok,the monitor is new,i dont understand why its stop working.
Old 05-18-2007, 04:35 PM   #5
meddler's Avatar
did you open it? if not send it back for warranty
Old 05-18-2007, 04:37 PM   #6
yes,i open it 2h ago first time...yes...i can hear you saying y on earth did u did it...
Old 05-18-2007, 04:41 PM   #7
meddler's Avatar
either it's the ribbon cable or you have damaged the controller board. The same thing happened to my xenarc. Try cleaning the contacts of the ribbon cable and then have a real close look at it. the cable could be damaged from when you pulled it apart.
Old 05-18-2007, 04:44 PM   #8
its not the cable for sure because i have two of them and they look new.i will try to clean them and see if somthing happan,if not...im going to sell the 629 in parts...
will let u know....tnx!!
Old 05-18-2007, 04:47 PM   #9
one more thing...if i move the cable without the connector is closed...shuld i see no vga signle or is a must to close the connector.?
do u know what side goes where? (the blue plastic on the cable)
Old 05-18-2007, 05:02 PM   #10
meddler's Avatar
Unfortunately I don't know which side goes where. I haven't opened up my lilliput. If it isn't the ribbon cable, it is probably the controller that is damaged.
The screen will show no signal if it is on and there is no vga signal input.
Old 05-18-2007, 05:16 PM   #11
where is this controller and it can be replace by a new one?
Old 05-19-2007, 02:53 AM   #12
clean the cable and still have white screen.i guess this screen going to be sell in parts...
tnx
Old 05-20-2007, 04:56 PM   #13
Hindmost is an unknown quantity at this point
"Poorly manufactured and prone to sudden failure." That about sums up Xenerac and lilliput screens lately.
Hindmost is offline   Reply With Quote
Lilliput EBY-701 / 629 thumper_svx LCD/Display 5 05-16-2007 06:55 PM
new revision Lilliput 629 factory mode not working!! pmp99t LCD/Display 0 10-10-2006 03:08 PM
lilliput 619 is reflective, 629 has antiglare? kbyrd LCD/Display 16 06-23-2006 08:44 AM
for sale - Lilliput 629 Touchscreen $200 my350z Classified Archive 1 10-31-2005 11:16 AM
Are the Lilliput 619 and 629 cases interchangeable? Darek85 LCD/Display 1 10-27-2005 03:01 PM
