Notices
Old 05-19-2007, 08:38 PM   #1
maniaxzero's Avatar
Weird Lilliput eby-701 problem! Help!
Ok. So i had this Lilliput lcd touchscreen for about a month. I set up the carpc in the house all this time. The Lilliput worked perfect never really had any problems. Now today, I installed the carpc in my car and I have +12 and ground wire coming off a molex connector from the m2atx to power my Lilliput. Everything is working well. The screen turns on, I see the bios, then the windows xp loading screen, then usually it would switch to the welcome screen but instead the Lilliput just blanks out and said it's not receiving any input. I tried restarting the carpc many times. Same thing every time. I see the bios, then the windows startup, then boom No input!
This leads me to believe it's something to do with the drivers. It's strange because it worked just fine in the house and when its in the car , it shows the bios and startup screen just fine so it cant be the powering.
Anyone had this problem before? This is driving me nuts.
Any help is appreciated. TIA
maniaxzero is offline   Reply With Quote
Old 05-19-2007, 08:42 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
yup. One of my first threads.
Hook up a regular monitor to your computer and change the output resolution to something other than what it is at now.
Probably 800x600 right? Change to 640x480 or 1024x768 and that should fix it.
It drove me crazy for a while.
I will find my thread and post a link. Man that sucks. Although in a slight way I am happier that I am not the only one.
Old 05-19-2007, 08:43 PM   #3
2k1Toaster's Avatar
http://www.mp3car.com/vbulletin/lcd-...io-ts-lcd.html
Old 05-19-2007, 08:45 PM   #4
greatwhite's Avatar
Toaster is right one the money. Same problem with my eby 701 whe I got it. But I would hit the auto adjust button by mistake and it went ot some weird resolution.
Hooked up the CRT, changed it back, problem solved.
Mine works fine on 800x600 though......
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-19-2007, 09:07 PM   #5
maniaxzero's Avatar
thanks for the advice guys, i will give it a try tomorrow. It's cold and rainy outside, I dont wanna go out at this time.
Old 05-20-2007, 11:26 AM   #6
maniaxzero's Avatar
Update: I brought the computer inside and hooked it up to a VGA monitor. Still have the same problem. BIOS shows. Windows Boot Screen shows. Then when it switch screens, it gets NO SIGNAL!
If i cant even get windows to display on a vga. How can i change the resolution?
Old 05-20-2007, 11:31 AM   #7
Let me be the first to say... F8 boot in VGA mode?
Thats right.. hehe
Before the XP splash screen boots, Press the F8 key repeatedly until the xp boot menu shows, then goto Enable VGA Mode to boot to 640x480 resolution.
Tony
tracker64 is offline   Reply With Quote
Old 05-20-2007, 11:36 AM   #8
maniaxzero's Avatar
Thats right.. hehe
Tony
tried it many times. It just ignores the F8 key presses and continues to boot windows normally.
Old 05-20-2007, 03:12 PM   #9
maniaxzero's Avatar
ok nvm. It was my wireless keyboard's problem. I plugged a regular ps2 keyboard in and pressed F8. Went into safe mode. Removed old intel graphic card drivers. Restarted. Re-Installed intel video drivers. Set resolution to 800x600. Rebooted. Seems to be working good so far. I hope this problem dont come back. BTW, i really appreciate all the help guys
Old 05-20-2007, 03:21 PM   #10
Your welcome
Old 12-05-2007, 11:06 AM   #11
i bought eby-701
today i made everything ok. Mainboard+Ram+CPU+Power Supply+Hdd+....
started to setup windows, everything was so good then the screen startedt to blink and completely got white. resetted pc but it turned itself off and now i cant turn the lcd on.
only power led is (red) blinking. Cant do anything. i am so sad, why can it be ? i cant send it to USA for warranty from Turkey.
i am trying to turn it of standalone but no change
nickelaj is offline   Reply With Quote
Old 12-05-2007, 03:49 PM   #12
2k1Toaster's Avatar
Quote: Originally Posted by nickelaj View Post
i bought eby-701
Sounds like a ribbon cable is loose. Specifically the button panel's. You open it up at all?
Old 12-06-2007, 05:14 AM   #13
no i didnt open. today tried again but nothing
only power led red blinking
Old 12-06-2007, 05:19 AM   #14
2k1Toaster's Avatar
Well if you arent sending it in for warranty, then open it up. Once you do, you cannot send it in, so make sure you don't/can't first.
Then check your ribbon cables. The big VGA signal ribbon as well as the smaller front panel ribbon.
Old 12-06-2007, 06:16 AM   #15
we tried it but nothing changed
below link is the same problem,
http://www.mp3car.com/vbulletin/lcd-...o-picture.html
Lilliput Touchscreen Driver Problem. gleinz LCD/Display 2 01-12-2007 12:30 AM
SUPER 7" Touch VGA screen, problem with drivers- same apps as Lilliput?... HACKTHS LCD/Display 2 07-22-2005 02:17 AM
Problem with Lilliput picture spaced_chris LCD/Display 12 11-23-2004 09:30 AM
Small Lilliput display problem Da_Teach LCD/Display 17 03-01-2004 07:23 PM
weird problem with lilliput durring bootup (with pic) djrkd LCD/Display 2 11-05-2003 04:01 AM
