The MP3car.com Store
Thread Tools Display Modes
Old 05-28-2007, 06:54 PM   #1
Vehicle: 91 300ZX Twin Turbo
My Photos: (0)
another PSONE question...
Is there a way to extend the controller from the screen? I want to mount the screen in a location the controller will not fit. There is a ribbon cable connecting the two, is there a way to extend it?
SoloCon is offline   Reply With Quote
Sponsored Links
Old 05-29-2007, 02:53 AM   #2
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
Yes, because the relatively low refresh rate you can extend it approx. 70-80cm or more.
The main question is: technically how? There is a connector and a ribbon cable, both of them are very small. Perhaps you can get a ribbon cable with a connector on the end. Be sure about the exact pin order!!!! Very easy to get a mirrored one instead of the wanted one!
bbalazs is offline   Reply With Quote
Old 05-29-2007, 08:29 AM   #3
My Photos: (0)
How would one go about doing something like this? Any pointers? I have never tired to extend a ribbon cable.
Old 05-29-2007, 10:23 AM   #4
stiv's CarPC Specs
Vehicle: ford exploder
My Photos: (0)
https://secure.lumenlab.com/shop/group.php?id=6
i did a ps one mod for an htpc a while back where i was gonna extend the screen. seemed liked to much work so i just modded the case a little.
lumenlab sells ribbon extensions. if you don't have much soldering experience that is the only way to go. these screens use to be very popular with DIY projector makers. what you are looking for is called an ffc extension cable.
hope that helps
stiv is offline   Reply With Quote
Old 05-29-2007, 01:41 PM   #5
My Photos: (15)
Stiv: the 20 pin we need is out of stock....
Solocon: If you have no experience, do not do that, because those tiny connectors and sensitive plastic foil. Ask an expert friend of you.
Old 05-29-2007, 02:58 PM   #6
stiv's CarPC Specs
My Photos: (0)
try this one
http://cgi.ebay.com/20-pin-FFC-flat-...QQcmdZViewItem
like i said these used to be very popular. lots of people have extended them.
search google for ffc cable extension.
Old 05-29-2007, 08:45 PM   #7
My Photos: (0)
stiv,
Thanks for the info. I am going to be looking at Ebay for a few longer ones. Is there a max length I should go?
Also, how do they hook to each other? I am guessing taping 2 sides together? Or something like that?
Again, thanks for all your help regarding this.
Old 06-02-2007, 02:24 AM   #8
My Photos: (0)
anyone?
Sponsored Links
vB code is On
Trackbacks are Off
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 05:15 PM
PSOne input question: multi-AV or mini-jack? Xylo LCD/Display 15 08-17-2005 01:16 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 09:03 AM
Another PSOne Mod question. Looked but no answer! Learic LCD/Display 5 06-27-2004 01:02 AM
PSOne Screen and Video MatrixPC LCD/Display 0 12-24-2003 10:24 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
