It is not entirely clear what you want.
Do you want a circuit board to convert an LVDS signal to to a TTL signal to drive a TFT panel. If so, have a look at the PCM-3540R from Advantech. I use this and it does a nice job (although I had to reverse engineer the bit assignments within the LVDS data stream since I wasn't pairing it with a PCM-3540T).
Or do you want a board to convert VGA to an LVDS signal to drive a LVDS panel. If so, I cannot help.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
