Old 06-11-2007, 09:31 PM   #1
EBY-701 Hard Reset??
Hi All,
Does anyone know how to hard reset a Lilliput EBY-701? My screen has auto adjusted to a weird size and i cannot seem to get it to display a normal picture again.
daboss is offline   Reply With Quote
Old 06-11-2007, 11:16 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
unplug the power, wait and plug it back in.
That should be all.
Old 06-12-2007, 12:41 AM   #3
how long do you have to wait; the screen retains the settings overnight (not powered)
Old 06-12-2007, 12:45 AM   #4
2k1Toaster's Avatar
Well should only be a few seconds. So if it retains it overnight while completely unplugged, then it is stored in memory somewhere.
This weird autoadjustment, did it happen when you were in a frontend such as RoadRunner? If so, then try to autoadjust when the desktop is active.
If that doesnt help, then try it on boot when the XP horizontal slide bar shows up.
When did this happen? (What was the active window)
Old 06-12-2007, 01:42 AM   #5
NiSlo's Avatar
Press the menu button on the screen and scroll though until you find the reset icon. Select it and then select yes.
If it's the monitor that is your problem, that shoudl fix it.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 11-13-2007, 04:08 PM   #6
Hey guys,
I have the EXACT same problem with my moniter, an HP w19. I accidentally hit auto adjust on my moniter when I was messing around with the brightness settings and now the window has been shifted over with a black bar filling up the empty space (if you guys don't understand what I'm talking about I'll send a picture.
I tried everything, I unplugged the monitor, my computer, and the link between the tower and the monitor and waited overnight- nothing. I pressed auto adjust again- nothing. I tried to manually adjust the vertical and horizontal positions- couldn't get it to move far enough, and now my vertical adjuster is screwed up (it says the image is at 255 and will not budge) Then, I tried resetting the image like NiSlo said- still nothing.
I need to hard reset my monitor or get the image back, any idea how?
Meep_head is offline   Reply With Quote
Add an Extra Hard Drive joesan MacCar 12 05-16-2007 10:35 AM
Brand New Hitachi Travelstar 5K120 80GB Hard Drive NIB Jir1984 Classified Archive 9 02-19-2007 10:20 PM
FS: Hard Drives adidas445 Classified Archive 2 01-10-2007 03:18 PM
My hard drive situation PhatHam Newbie 3 10-26-2006 12:50 PM
Ding Dong my hard drive is gone :( xBrady General Hardware Discussion 17 10-18-2004 09:57 PM
