Notices
Old 06-14-2007, 11:02 PM   #1
Newbie (I know!!!) needs lcd/controller advice
This is sort-of a cross post. I'm working on a back-up camera system for my new FJ Cruiser. I have very limited space where I want to put my lcd screen. I've searched the net and found a whole plethora of lcd modules that will likely work. There are a limited number of them that will actually take an ntsc signal... most of the panels I like require ttl. Now for the question... Is there anybody here that would be willing to coach me through the necessary controller boards I would need to get in order to convert a composite signal from a backup camera into either ttl or rgb?
TIA,
Russ
rtarver is offline   Reply With Quote
Old 06-15-2007, 03:32 AM   #2
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
why don't you use a xenarc or a lilliput. They come with composite video inputs if you choose the right model. You can save on space by removing it from the case.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 06-15-2007, 03:55 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
email motorcity. He would know better than any of us.
Old 06-16-2007, 11:28 AM   #4
found it.
Thanks guys... I like the lilliput stuff, but they're much too big. I'm limited to a 3.5" monitor. I ended up buying an lcd module that has ntsc input... got tired of trying to find the perfect module and settled on the smallest frame 3.5" I could find.
Thanks again,
Russ
Another newbie looking for advice on hardware cid_mcdp Newbie 2 06-29-2005 11:47 AM
PURE newbie - need advice and feedback Isis Newbie 4 04-20-2005 06:48 AM
Carputer Newbie needs advice. Deba Newbie 0 05-26-2004 04:42 AM
Ambitious newbie seeks all sorts of advice kerowhack Newbie 1 02-08-2004 07:42 PM
First System Build - Need advice on screens - Real Newbie Griffin_Dodd LCD/Display 0 01-31-2002 01:38 AM
