Quote:
There are no monitors to select from on the display options. Anyone know how to get more listed/installed there?
Sorry, I am a little confused. What monitors in what list?
As to solutions, if you can get it to work for a while you may have some luck by changing the cmos battery. To get you up and running, make sure monitor is set to CRT in your bios. Then try booting into VGA mode and then uninstalling the S3 vga drivers. Do NOT reinstall them if prompted while still in VGA mode, also do not let the computer optimize your display(or whatever it calls it) while in VGA mode. Now restart the computer let it go back into windows xp. You can't stop it from installing the S3 drivers in full xp, but that's ok. wait until it is finished, then right click on the little yellow box in the taskbar that says S3 and tell it not to run at start up. Make sure you do this before the computer restarts (it will want to restart after installing the drivers). Once the S3 utility(yellow box) is disabled restart your computer. It should boot up into windows fine. Oh, you may have to do this initially with another monitor, if that is the case you want to put the computer into hibernation, after getting everything working, and swap the monitors while it is in hibernation, otherwise you may have to start all over again.
This fix only worked for me for about a week or two, and then I would have to fix it all over again. It started happening with more frequency which leads me to believe that the problem was my cmos battery was dead, and anytime the computer lost power the bios reset. I finally got fed up with it and installed a pci video card I had laying around and everything works fine. It looks better too.
Oh if you have wifi on your computer install vnc whenever you get it up and running. That way if it acts up you should be able to fire up tight vnc and fix the s3 utility from the comfort of your home, rather than have to drag a monitor out to your hot car.
If this doesn't fix your problem, then there may be something else causing the issue.
Hope this helps.
