Old 06-23-2007, 12:37 PM   #1
dww 700h problems
I purchased a 700h off of ebay last week. It was brand new in the box, never been installed. When I installed it, I only receive a white screen. The touchscreen does work on it, as I have it hooked up to a laptop, and using the touchscreen on the 700h moves the cursor around on the laptop screen. I have installed approximately 20 head units in vehicles, so I am confidant that I know how to properly wire.
I used a digital multi meter to ensure that the acc wire is hooked into a switched power source, and the 12volt constant wire is hooked to a wire I ran straight from the battery. The ground is also correct. The white screen comes on regardless of whether the car key is in the run, acc or off position. I have rechecked all wires several times. Is the screen bad? or am I not doing something correctly here?
griz145389 is offline   Reply With Quote
Old 06-26-2007, 11:58 AM   #2
Anyone have an idea with this before I have to file a paypal dispute?
Old 04-06-2008, 03:28 PM   #3
did u ever get that white screen issue solved? i'm having same problem
Worklog: http://camrycarputer.blogspot.com/
hommeg is offline   Reply With Quote
Old 04-12-2008, 06:22 PM   #4
I had this same problem. At first just during cold weather, then all the time. From what I've read it is quite a common problem with these units. I tried to contact Armen at digitalww for a refund/replace/repair, but he never got back to me. Now the warranty is up and its just sitting here. $300 piece of junk.
It's a shame, because while it worked it was actually pretty decent.
** Denotes an "in car" post
In-Car posts made from passenger seat - be safe,Don't Post and Drive.
walky_talky20 is offline   Reply With Quote
Flash Problems.... Flash Problems... and MORE Flash Problems!!!!!!! JohnWPB Road Runner 33 03-28-2008 02:18 PM
Harddrive problems (booting) Axxess General Hardware Discussion 1 05-15-2007 04:13 PM
Road Runner & Blue Devil - MapPoint 06 & playlist problems toones Road Runner 4 12-27-2006 03:22 PM
Car voltage problems cheerio General MP3Car Discussion 2 08-16-2004 08:01 AM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 01:55 PM
