Old 06-25-2007, 07:36 AM   #1
mrspangle's Avatar
mrspangle is on a distinguished road
Exclamation Screen interference issue! Help!
Hi,
I've got a weird video interference issue which my current install.
If I play music through my carputer my screen upfront flickers in time with the beat of the music.
1) If i disconnect the RCA connection to my amp and play music - interferenace stops
2) If i connect an MP3 player to the RCA connection of the amp - interference stops
I've tried the following:
- Sanded and cleaned ground connections (0 AWG)
- moved the VGA connection to the otherside of the car from the power cable
- Attempted to ground the computer case- made no difference.
Can anyone suggest anything else?
John
mrspangle is offline   Reply With Quote
Advertisement Sponsored links
Old 06-27-2007, 04:57 AM   #2
mrspangle's Avatar
bump
Old 06-27-2007, 06:34 AM   #3
OptimusPrime's Avatar
OptimusPrime is an unknown quantity at this point
I have a similar issue, although my interference is permanantly there
What method are you using for power? (i.e. cig lighter etc)
What refresh rate are you using?
OP
OptimusPrime is offline   Reply With Quote
Old 06-27-2007, 08:01 AM   #4
mrspangle's Avatar
Ive got the DWW6500 double din screen, its powered through the ISO loom in my car.
I think the refresh is 60hz
John
Old 06-29-2007, 07:05 AM   #5
mrbean_phillip is on a distinguished road
Use a DC-DC inverter to get rid of your problem - something like a M2-ATX or Carnetix.
Have fun.
mrbean_phillip is offline   Reply With Quote
Old 06-29-2007, 03:35 PM   #6
mrspangle's Avatar
I already have an Opus 150w installed, its not an option to connect the screen to the psu. As the screen turns the psu on!
John
FAQ: Everything you need to know about your LinITX/MM400/TView Scouse Monkey LCD/Display 27 12-25-2007 11:34 PM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 11:55 PM
xvid full screen playback issue MycoDeX Road Runner 1 07-16-2006 01:17 PM
Possible solution for people with screen interference (Pics) live2themaxuk LCD/Display 16 05-30-2006 12:21 PM
Inverter making the screen go off and on, and cut it. PLEASE HELP clean customs Power Supplies 23 01-20-2005 07:41 PM
