Old 06-27-2007, 09:00 AM   #1
Skipjacks's Avatar
Skipjacks is on a distinguished road
Did I kill my Lilli?
So here's the deal...messing with the system last night...monitor power cord must have been frayed or something because when it touched a grounded metal part of the car there was a big spark and then immediately the monitor refused to even show the standby red power light. Doesn't turn on, nothing.
Sure sounds like a power surge fried it. Is there a fix for this? I looked at the board inside of it, hoping there was a fuse somewhere that could be easily fixed, but that was asking too much I guess.
Is there a fuse in there that I missed?
And if not, is there at least a decent chance that I could buy a broken replacement screen (one where the LCD was shattered or something, but not fried) and just swap out the rear circuit board in the monitor for one that hasn't had heavy amp loads flung at it?
I'd like to replace a component for less $$$ than buy a whole new unit.
If not, the next step is to buy one off someone where the touch screen element is busted and just swap my good touch screen out.
Mine has the same case as this one...
http://store.mp3car.com/Lilliput_7_V..._p/mon-001.htm
I assume this is the model I have. It's been 3 years since I bought it and I forgot the part number. I'm guessing that the 619 is the only one that uses that exact style plastic housing.
Skipjacks is offline   Reply With Quote
Old 06-27-2007, 09:38 AM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
there is a fuse in there, right bt the DC jack there is a white square with two silver ends, that is a fuse.
if you do a search I believe there is a thread with pictures.
http://www.mp3car.com/vbulletin/lcd-...ened-me-2.html
found thread
Enforcer is offline   Reply With Quote
Old 06-27-2007, 09:40 AM   #3
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Also if the fuse isnt blown, then check what the voltage regulator is putting out. Those are an easy fix. Good luck.
Old 06-27-2007, 09:51 AM   #4
Skipjacks's Avatar
Quote: Originally Posted by 2k1Toaster View Post
Also if the fuse isn't blown, then check what the voltage regulator is putting out. Those are an easy fix. Good luck.
Let's pretend for a second that the voltage regulator was ****ing me off because it seemed to have a short in it (obviously a short, everything powered on but dimly, and the voltage was low) and I just took the egg out of the circuit.
Would that be bad?
The Lilli worked fine after I took out the voltage regulator. It wasn't until about 20 minutes later when the wires got crossed that everything went haywire.
But when I do get all this put back together is there a problem with skipping the voltage regulator? My car outputs a pretty constant 12V. It's good about that. But is this a bad idea anyway?
Old 06-27-2007, 09:54 AM   #5
Skipjacks's Avatar
found thread
You are the 'effing man!
Old 06-27-2007, 10:04 AM   #6
Confusion Master
Enforcer's Avatar
Don't use it without a regulator.
Also it is better to use one other than the one supplied, because they are crap, as you have seen.
I have got a proper 12v reguator that I can power a number of screens off.
Old 06-27-2007, 10:36 AM   #7
2k1Toaster's Avatar
(Enforcer)
But the regulator I was referring to was the onboard regulator. Probably 5v or 3.3v. It should be in a TO-220 package close to the power jack.
Old 06-27-2007, 10:36 AM   #8
Skipjacks's Avatar
I should be able to get that in any electronics store I imagine?
Old 06-27-2007, 10:51 AM   #9
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Probably not.
If you use inverter in the car, yes a 12V wall plug will do it. Or you can just use a 12V coming out of the PSU (Yellow is +12V and Black is -).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-27-2007, 11:15 AM   #10
Skipjacks's Avatar
Quote: Originally Posted by MatrixPC View Post
Probably not.
That'd be a pain in the butt. The power supply and inverter and all that business is in the trunk. The last thing in the world I want to do is run another wire under the carpet up to the dash. That was a royal pain the first time.
I will gladly accept links to online stores that sell regulators though...
Old 06-27-2007, 11:28 AM   #11
Confusion Master
Enforcer's Avatar
(Enforcer)
looking at\one of the two I have in front of me there is a chip with B1203 written on it, looks like a very small 7805
I had to get mine online
Will be UK ones if I can find where I got mine.
Old 06-27-2007, 11:34 AM   #12
2k1Toaster's Avatar
The B1203 is just a high-current transistor. It doesn't regulate voltage, but there should be a chip for regulation somewhere.
Old 06-27-2007, 11:36 AM   #13
Skipjacks's Avatar
Well let's not get ahead of ourselves here. The fuse the enforcer mentioned is most likely the problem based on the symptoms. The death was sudden, and after a short in the power line. A fuse is 98% likely to be the culprit.
I'll deal with on board voltage regulators only when I have to.
Old 06-27-2007, 12:33 PM   #14
Confusion Master
Enforcer's Avatar
Ahh! go on, start dealing with them now
Old 06-27-2007, 12:34 PM   #15
Confusion Master
Enforcer's Avatar
Packed the screens away for now so I can't look. Might have a look tomorrow when I get them out to play with again.
HOLY CRAP.....this is insane cadence117 Off Topic 13 06-17-2008 07:37 PM
Power Supply/OPUS Kill Switch SpaceMonkey Power Supplies 8 08-11-2006 11:58 AM
Lilli only *half* broken. silencery LCD/Display 0 04-04-2005 03:00 PM
Lilli ghosting. Searched and still need help maxxell LCD/Display 1 03-24-2005 04:01 PM
Lilli 7" XP monitor type Won't sync 800x480 BMVEE LCD/Display 3 03-24-2005 09:46 AM
