Old 06-28-2007, 01:48 AM   #1
blackmz3's Avatar
blackmz3 is on a distinguished road
connecting xenarc power wire to molex
ok i read how to wire to a molex but i have a problem. im not sure which is power and ground. i bought this xenarc used and they only gave me one wire which looks like this after i remove the covering.
left: black rubber covering
middle: white wire with silver strands coming out
right: silver strands sort of wrapped around the white wire.
im assuming the white is power and silver is ground. just want to make sure.
blackmz3 is offline   Reply With Quote
Old 06-28-2007, 02:21 AM   #2
mrbean_phillip is on a distinguished road
White is power, silver is ground.
mrbean_phillip is offline   Reply With Quote
Old 06-28-2007, 02:52 AM   #3
blackmz3's Avatar
woot...thanks mr bean.
Old 06-28-2007, 03:10 AM   #4
You're welcome
Old 06-28-2007, 09:13 AM   #5
TBAPb is an unknown quantity at this point
Yep, this is great. My friend did it and now it;s working off his M2.
TBAPb is offline   Reply With Quote
Old 06-29-2007, 01:50 PM   #6
blackmz3's Avatar
yup, that's what im planning to do.
2008.5 White MS3 Sport
Cobb Shifter Weight | Cobb SRI | Cobb AP | Cobb Turbo Inlet
HKS BOV(Recirc) | Defi Boost Gauge| TRZ Tranny Mount| F2 BSD | F2 Oil Baffle
Old 06-29-2007, 03:21 PM   #7
Snortonnorton is an unknown quantity at this point
can you post pictures of how you connected it to your molex? which color molex does it go to?
I have a M2 ATX power supply as well.
Snortonnorton is offline   Reply With Quote
Old 07-04-2007, 03:55 PM   #8
blackmz3's Avatar
i will when i get to it. im installing the OS right now. i'm going to solder the white wire to the red wire coming from the molex connector and the silver wire to the black wire from the molex connector.
Old 07-05-2007, 11:38 AM   #9
SLAYER6669
The white power should go to the yellow (12v) wire on the molex connector. The red wire is only 5V
1991 Camaro Z28
2004 Acura TL
Thirdgenfbodies.com
SLAYER6669 is offline   Reply With Quote
Old 07-05-2007, 12:18 PM   #10
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Correct. In case someone searches and does not already know the Black wires on the PC molex connectors are both ground (earth).
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-05-2007, 04:25 PM   #11
blackmz3's Avatar
oh...i thought it was the other way around. damn...the connector i have only has a red and black wire. i'll figure something out.
Old 07-06-2007, 07:34 AM   #12
mrspangle's Avatar
mrspangle is on a distinguished road
Does anyone know what the maximum current draw can be through a molex?
I want to connect my DW6500 through the compueter, but it says maximum of 10a - is this too much?
mrspangle is offline   Reply With Quote
Quality of power, signal, and speaker wire? cherrybomb Car Audio 10 01-11-2007 07:55 PM
12 Guage power wire??? Stillalive2029 Power Supplies 11 06-28-2006 11:04 AM
Newb question about power from a Molex dsballer2000 Power Supplies 7 06-25-2006 12:32 AM
xenarc power question for adding a camera DBrisson LCD/Display 0 01-08-2006 05:56 PM
Opus wont power, green wire has constant 5v??? jedi7001 Power Supplies 3 02-22-2005 11:30 AM
